ACER LAPTOP AND NERO COMPATIBILITY
I HAVE AN ACER ASPIRE 9302AWSMi LAPTOP - I HAVE HAD NERO INSTALLED SINCE PURCHASE AND HAVE RECENTLY HAD PROBLEMS BURNING DVD'S - MESSAGE SAYING COMPATIBILITY ISSUES WITH NERO DVD ROM??
I HAVE INSTALLED A NEWER VERSION OF NERO AND STILL HAVE THE SAME PROBLEM - I CAN BURN CD'S BUT NOT DVD'S
HELP!?
Will 2GB DDR2 PC2-5300S Laptop memory work for acer aspire 4315-2963
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
Jan 28, 2013 | Acer Aspire 4315-2963 Notebook
Hi. My Acer Aspire 9302AWSMi is completly dead. The Power botton is green vhen I turn the power on, and the harddrive lamp flashes ones. and then notthing happens
Probably a Motherboard or a Monitor problem. If it's still in it's warranty, you might consider taking it in for repairs.
Jun 05, 2011 | Acer Aspire 9300 Notebook
My acer aspire 9302AWSMI, will not boot up, i only get a black screen, not even a harddrive start ?? I have read earlier that this model has a problem with black sreen cause of bad cabeling to the...
Its your motherboard. It has crashed and the only way to fix your problems with the hardware is to replace it. Its nothing to do with the cabling, if your hard drive does not start up.
Hope that helps
Mar 23, 2011 | Acer Aspire 9300 Notebook
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
I recently updated to Windows 7 on my Acer Aspire 5500, everythinh works but my Wlan is not recognised it does not appear in my network devices and all the drivers I have downloaded do nothing? Any ideas?
Check in the BIOS to make sure it is enabled (press F2 repeatedly during startup), and make sure that the switch (mechanical) for it is on. (Page 10 of this manual; you may want to download and save it)(http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS3600%205500-ENG-OLM_0609.pdf)
The fact that Windows 7 does not see it is indicative that it is either powered off in the BIOS or shut off mechanically.
Good luck; if you are still having problems, repost and we'll see what we can do.
Mar 11, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 1690 cooling problem whit windows vista
Windows Vista is a very demanding Operating system when it comes to system resources and it doesnt come as a shock to hear that you computer runs warmly, If you werent experiencing any problems when you had windows XP installed, I would suggest downgrading to Window XP, otherwise wait for October 22 and purchase a genuine copy of Windows 7 and use that.
Jun 18, 2009 | Acer Aspire 1690 Notebook
Acer aspire 5050 is havin problm
google "acer aspire 5050 webcam drivers"
click a site, download ,then install
Aug 24, 2008 | Acer Aspire 5050-3242 Notebook
I have an Acer Aspire 5315 Series laptop, and have been having some problems with the wireless modem adapter that is installed into the computer. I recently did a change of the OS system, from Vista, to XP...
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=2246261&CFTOKEN=17581077
Above is the link where you can download all the drivers for your Aspire 5315 series laptop. It is directley from the Acer support site and it is free. You do not have to buy the CDROM.
I hope you find this helpful. If you do please don't forget to rate me FixYa.
If you ever need other technical support feel free to contact me. Always free as for all the times others have helped me for free.
Thanks
George
Jul 18, 2008 | Acer Computers & Internet
Windows Movie Maker is Pixelated
Try this..
Open Movie Maker
Goto TOOLS - OPTIONS
Open the Compatibility Tab
Remove the ticks from ALL filters EXCEPT the Microsoft ones.
If there are only MS filters, the remove the tick from those also.
Post back the results please =)
Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
David Payne
David Payne
