Question about HP DeskJet 895cse InkJet Printer
Prints crooked My printer starts with the top lines running lower as it reads to the right, then gets straighter as the lines get closer to the bottom of the page. As if the spaceing between lines is larger on the left side of the page. Is there any adjustment for this? lvhdude@yahoo.com
  • joe rich Apr 02, 2007
    I found the problem, funny no one out there was any help.
  • 432 Answers
What was the problem? How did you fix it?
Posted on Jun 26, 2007
I'm having trouble addressing an large envelope the printer wants to print from the upper photograph tray and not accept the envelope from the lower tray. I have the MX922 printer.
The upper tray on my 6120 has adjustable guides on either side of the document and can be set from 2" to 8.75" wide. It is not intended just for photos! I use it for ALL envelopes that will fit. I use the MS WORD "Mailings", "Envelopes", "Options", "Envelope Size" menu to tell the printer what size the envelope will be (any size not listed in the standard list can be customized from the CUSTOM option at the bottom of the envelope list). Your word processor should have something similar. Running from the tray should be a straighter run and will actually place less distortion stress on the envelope.
Use a mailing label for anything larger than 8.75". You can download a program from Avery (and probably other label manufacturers) that really makes labels simple to produce. Labels should also be run from the rear tray if possible so they won't wrap around your rollers.
Happy Printing.
Feb 10, 2015 | Canon Pixma MX922
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
My HP 2410 photosmart printer has started to print everything crooked. The paper is going through perfect but the printer left margin starts to increase about half way down the page. At the bottom the...
probably a simple alignment problem. Go into your maintenance section and there is an option to align . Run this and it should realign your printing. Hope this helps!
May 09, 2011 | HP PSC 2410 All-In-One InkJet Printer
My computer says that the printer is offline, it worked just fine a week ago.
Did you click on the print manager box, there is a parameter in there that will be checked if it is OFF LINE. Click on that and it will put you back on line. The easiest way to find it is to try and print something, when the little printer shows up in the lower toolbar or if you get a popup when the print failed, you will have access to that info by clicking on the box.
Mar 25, 2011 | HP Office Equipment & Supplies
Media problem during printing
If the media is coimng out straight, then look at the cutter mounting.
If the cutter is slightly off angle then it can be corrected on the mounting beneath the right lower side, and the lft upper (head latch) side.
Try printing a barcode or straight line of print on the top and bottom of the label. Look at the print in relation to the cut.
If it is off , it may also be the printhead azimuth.(angle of the head in relation to the platen roller(roller beneath the head).
There is an adjustment fo tthe head to suare it up to the platen.
Jan 27, 2010 | Zebra 105SL Thermal Label Printer
I print on labels and the print is too high. How can I lower Print on page?
hold go and return power on the printer until in the screen you see it start to veify ram then release. this will bring the printer up to registration hit select there will be 4 settings showing right left top and bottom. use the select button to move from setting to setting if the print is to high minus from the number showing in the top position make the same number change to the bottom setting untill the print is in the right position. remember or make note of these changes if the print gets further away reverse your changes
Nov 04, 2009 | Lexmark T640 Laser Printer
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Jul 19, 2009 | HP Office Equipment & Supplies
Canon MX310 not printing properly
If you are running Windows XP, you should be able to go to Control Panel> Printers and see your printer. Right-click and go to properties. From there you should be able to align the print cartridges and that should fix the problem. If problem persists, contact your manufacturer.
Jan 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Won't print anything
go to my computer
right click properties
hardware
device manager
?printer
scan for hardware changes
then try to print
Aug 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP DeskJet 895cse InkJet Printer Logo
66 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
