Question about Honeywell Programmable Thermostat Heater
Blower not working with new thermostat
I am replacing an old turn dial Honeywell thermostat with a new programmable ATX500 series thermostat. I have an extra blue wire that I have tapped off, but on the old thermostat blue went to green and the green went to a 'H' terminal. Long and short I need to figure out how to wire this thermostat so my blower will work.
  • 1,420 Answers
To get the fan to work, look at the heating system to see what termoinal the blue wire is connected to. It should be the "G" terminal. If so, connect the blue wire to the "G" terminal on the thermostat and then manualy switch the thermostat to "Fan On". Indicate what terminals you have on your new thermonsta ie "G" "R" "Y" "C" "W" etc... For a fan to work, typically you connect "R" to "G" on the furnace.
Posted on Nov 07, 2008
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
My old thermostat has only yellow and red wires...no green and white like my new Honeywell thermostat installation instructions mention. Is this a problem?
The green wire is used to turn on the blower if you want constant air circulation. For heat only, the red and yellow wire will work as long as they are connected to R and W terminals on heating unit (or TH and TW on some models).
Nov 20, 2010 | Honeywell Programmable Thermostat Heater
New thermostat not cooling. Blowing heat instead.
Hello You have only 5 wires? multi stage if so ,is run by something else.Check that RH/RC is jumped out on new stat.Also check that O is not on the B terminal.If there is an A/B select switch set it to O.Emergency heat button dont matter as there is no wire to run it with only 5 wires.
Apr 17, 2010 | Honeywell Programmable Thermostat Heater
I want to replace programmable thermostat with old dial style
The terminals should be the same on both thermostats, except for C- common.
R- usually RED, goes to hot side of transformer,
W- usually WHITE, goes to heat
Y- usually YELLOW goes to outdoor unit
G- usually GREEN goes to furnace blower
Any of the other wires just cap them off you don't need them. If you have an Rh and Rc terminal instead of R and don't have them on the programmable then put a jumper from Rh ro Rc.
If you need more, then let me know what terminals you have on both t'stats and brand of furnace and AC, if you have a heatpump then there's more wires let me know.
Oct 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
New programmable thermostats will not operate the furnace or air
did u turn the power off to unit before installing t-stats,if not then mabe blown low voltage fuse
Mar 28, 2009 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
238 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
