Shows 5e fault - Washing Machines
Debree filter located at bottom right on the front of the washing machine is blocked. Power needs to be turned off, and compartment to filter opened with a coin before cleaning, there is a hidden tube again to the right and below the filter, pull out cap to this and put bowl below to catch water - there is rather a lot of water so important to do this. Don't forget to clean the filter once water empties out.
Posted on Dec 30, 2008
My top loader washing machine shows SE. Please assist.
Hi!
I has the same 5E mistake with my Samsung washing mashine.
5E looks like SE on the screen, but it is 5E.
This is what the manual says:
5E - Your washer is not draining. It can
also mean that the unit senses a
small clog while draining
Do the following:
1) Turn off the unit and turn it on again.
2) Select only the Spin Cycle.
3) Press the Start/Pause to drain the water.
If it still does not drain, call for service.
Apr 26, 2017 | Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
WASHING MACHINE SHOWING ERRORMESSAGE 5E
rw
Hello, and sorry to read about you 5E code issue.
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
If your hose shows no kink's you may have a clogged pump.
I have tried to help you. PLEASE rate/vote the response. we take the time to respond to you. take the time to rate. Thanks and good luck on your problem.
Dec 24, 2010 | Samsung WF306BHW High Efficiency Front...
Kenmore (Whirlpool) Elite Electric Dryer 110.64086201. Diagnostic check generates a 5E fault code. What the heck is that?
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 28, 2010 | Kenmore Elite HE4 Electric Dryer
Error code SE or 5E
'SE' is a temporary sensor error. Switch off power at wall plug, wait a few seconds, switch it back on and it may clear the fault.
Mar 28, 2010 | LG Washing Machines
My Worcester Bosch Greenstar 25CD1 is flashing 5E
the code is SE saying it needs a service it can be reset go to this link for a pdf file showing how to http://www.worcester-bosch.co.uk/cache/file/239/guide-to-re-setting-the--se--code-on-greenstar-cdi-boilers.pdf
Jan 24, 2009 | Audiovox Bosch 718 World Cellular Phone
I have j1045 front load samsung 7 kg washing machine it shows 5E message and its not draining properly.we cleaned the filter, and drainage hose is not jamed.what should i do
The display should say 5E, this means that it's not draining. unlucky for you as this means you have to replace the drain pump, wich aperently cost about $137NZ. this seemes to be a common fault. i'm not a teck, but I just had the same thing happen, lucky for me i had a warranty.
Other simptoms are the loud racking noise coming fromn the washing machine. home this helps.
Jun 21, 2008 | Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
