Zanussi IZ161S Front Load Washer
Problem for Zanussi IZ161S Front Load Washer
Bearing noise
By oaks on Oct 09, 2006
I had major bearing noise on my zanussi washing machine, managed to source bearing/seal set from local supplier. got back off machine, removed pulley for belt. Not sure now whether to remove drum assembly completely or to split outer drum all way around middle and remove back half to get access to bearings etc. Any one got any suggestions which would be really appreciatted.
thanks.
Best Solution
posted on Oct 10, 2006
Helpful)
WASHDOCTOR
Rank: Guru
Rating: 87%, 243 votes
Hi there im the wash docotor.
With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch
Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Zanussi IZ161S Front Load
Questions and Unsolved Problems for Zanussi IZ161S Front Load
Do you recommend Zanussi IZ161S Front Load Washer?
Answer
Answer
I have a 10 year old (?) Zanussi IZ16 washing machine that has been working fine for all of its... (More)
Answer
IZ16s reading E20 and E40 codes what are they?
Answer
Hi, this problem trips my home's electric circuit, but doesn't blow the washing machine plug fuse.... (More)
Answer
Hi, I have a problem when i try to do a wash..in between the machine starts beeping and an E20... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi IZ161S Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
