Question about Compaq Keyboard
Cannot get the letters working right
When I click the letter H I get a Y and so on can you please help?
    President:
  • 2,992 Answers
Your need a keyboard. I'm guessing you have a laptop. (If you have a desktop, just buy a replacement keyboard anywhere and you'll be set.)
Here is a possible source:
http://www.machinaelectronics.com/
I purchased some laptops parts from them for repairs and have been satisfied.
Posted on Dec 06, 2008
I CANT SEE MY FILES THAT i SAVED ON F IN MY USB FLASK DISK INSTEAD THE USB OPEN ON G WHICH I DONT HAVE ANY SAVED FILES
If there is no F drive, then you can change the G drive letter to F drive letter. If the F drive is occupied by other device, then you can change the F letter to J letter, and then change your G drive letter to F drive letter. Here is how to change the drive letter:
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management, click on the Drive G and right click it; it will display Change Drive Letter and Paths.
Mar 02, 2014 | Computers & Internet
Tip
What to do if your USB is not detected on your PC...
Hi Everyone,
If you are experiencing problems with Windows detecting your USB drive (Storage, MP3 or iPod), follow these steps to get them back. These problems are usually caused by either viruses or a damaged sector on the drive itself. Formatting the drives after enabling them, would usually restore all the functions back to normal.
IF USING WINDOWS XP:
Follow these simple steps,
- Right-Click on My Computer, and select "Manage"
- On the Right hand panel select "Storage" - Double Click on it
- Double Click on "Disk management(Local)"
- Your disk will most likely show here with NO Drive Letter
To fix it, assign a new drive letter to it by doing the following:
- Right-click the drive, and select "Change Drive Letter & Paths"
- Press Add.. select a letter and hit OK twice - It should now be visible.
IF USING WINDOWS VISTA OR WINDOWS 7:
- Open the Start Bar (Lower Left Corner by default)
I hope this tip has helped you combat those pesky USB errors.
* If you found this solution helpful, please vote positively.
on May 11, 2011 | Computers & Internet
My transcend 4gb pendrive, JF V10 is not working at all. my pc dtects the drive, but i cant open it. "please insert disk into drive" - pops out. 0 bytes is shown when i view the properties....
Right click on my computer , left click manage , click storage - disk management
in the top section of the window see if you can see your pendrive .. if you can then check the drive letter it was assigned , then check if one of your other drives hasn't already being assigned that letter , if so right click ont the pendrive in disk management console - select change drive letter and paths..... -
select a another letter for the device - one that hasn't been used yet
reply if u were unsuccessful
thanx
May 27, 2011 | Computers & Internet
The usb is not detecting to pc.how to get it detectable
I take it you are using Windows XP?
Do the following,
- Right-Click on My Computer, select "Manage"
- On Right hand panel select "Storage" - Double Click
Assign it by doing the following:
Good Luck :-) - J.Q
Feb 16, 2011 | Computers & Internet
Device doesn't work. maybe it needs new drivers
The following is from Windows Help, which I found by looking up drive letter:
  1. Open shortcutcold.gifComputer Management (Local).
  1. In the console tree, click Disk Management.
  2. pluscold.gifWhere?
  1. Computer Management (Local)
  • Storage
  • Disk Management
  1. Right-click a partition, logical drive, or volume, and then click Change Drive Letter and Paths.
  1. Do one of the following:
  2. To assign a drive letter, click Add, click the drive letter you want to use, and then click OK.
  • To modify a drive letter, click it, click Change, click the drive letter you want to use, and then click OK.
  • To remove a drive letter, click it, and then click Remove.
important.gif Important
  • Be careful when making drive-letter assignments because many MS-DOS and Windows programs make references to a specific drive letter. For example, the path environment variable shows specific drive letters in conjunction with program names.
Jan 31, 2011 | Buffalo Technology (HD-HB250U2) 250 GB...
My new DVDRAM GH22NS50 don`t work.
Please go to start - computer - right click - manage - disk management
If your DVD drive is visible - right click - change drive letter paths - change - choose new letter
Is your DVD visible in my computer, if it is repeat the process and change back to previous letter.
If it is not there, reboot the computer and it should show up.
Dec 10, 2010 | Computers & Internet
When A USB thumbdrive is plugged in, it is reconized but then it doesn't show a drive letter in "my computert" in order to transfer to or from the drive. The safe eject tab is present and does give a drive...
You should plug in the thumb drive, wait for it to recognize it, and then right-click on My Computer. Select the Manage option. Inside the Computer Management window, go down to Disk Management on the right side. The left pane will show you all of your local drives (hard drives, CDRW, USB, Flash, etc...). If you see your thumb drive listed in the drives, you can right click on it and select "Change drive letter and path". This will allow you to pick the drive letter you want as long as it doesn't interfer with any other existing drive letter.
May 13, 2009 | Toshiba Satellite Pro 4600 Notebook
Installation problem
hi verna833
Please right click on my computer and then go to Manage
Then click on disk management.
Now on the right you should see all the hdd and storage devices attached to your pc.
Now look for one without a drive letter. ex(c:, d:, and so on)
once you have found the one without a drive letter, right click on it and then and click "change drive letter and paths"
Then give it any drive letter that is availible.
It should work then
Apr 27, 2009 | Computers & Internet
Ilo mp3 I cant erase or add music
If you are running windows XP.
Right-click on the Start button. Click properties. While in the Start Menu tab click on Customize... button. Under Start Menu items, scroll to the bottom of the list and click the Display on the All Programs and Start Menu under System Administration Tools.
Now, click ok to finish these two windows you have open.
Click Start,
Click Administrative Tools,
Click Computer Management.
Now on the left side there will be System Tools, Storage, Services and Applications. We want to use Disk Management to see what drive letter is assigned to your mp3 player.
If you see a drive that does not have a letter assigned to it. Right click on the drive and pick Change Drive Letter and Paths...
Assign it any letter that you like (that isn't already used by another drive on this list,) and you should be able to view your files to add or remove just like another drive.
Most common reasons for this happening are... You are connected to a network that assigns drive letters to remote drives, or you have usb devices (like card readers) on your computer that have been assigned the letter that your mp3 player wants to call itself.
Please let me know if this helped you fix your problem.
Dec 01, 2007 | iLO (2 GB) MP3 Player
Kds laptop
Follow the following instructions for XP:
Top open computer management, right click on My Computer and click on Manage.
To assign, change, or remove a drive letter
minuscold.gifUsing the Windows interface
  2. In the console tree, click Disk Management.
    pluscold.gifWhere?
    • Computer Management (Local)
    • Storage
    • Disk Management
  3. Right-click a partition, logical drive, or volume, and then click Change Drive Letter and Paths.
  4. Do one of the following:
    • To assign a drive letter, click Add, click the drive letter you want to use, and then click OK.
Oct 11, 2007 | Computers & Internet
Compaq Keyboard Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
