Question about Sony SPP-S2730 Cordless Phone
Cordless phones will not connect to base.
I have 3 cordless stations and phones in the house along with the Base phone station that each cordless is registered to. A few months back, I noticed that one of the cordless phones wouldn't connect to the base. (Normally, you would press a number or talk and it would say "connecting" for about a second, then switch to the dial or talk interface. Now it just says "Connecting" for about 5 seconds, then says "error".) After a little while, all 3 phones turned up like this. I've tried unregistering and reregistering the phones, but they won't reregister. Help me out here.
  • 4 more comments
  • Tommy Detlor Oct 09, 2006
    I'm going to need a serious solution here.
  • Anonymous Nov 12, 2007
    cordless will not connect
  • Anonymous Nov 21, 2007
  • Anonymous Mar 05, 2008
    will not connect to base phone. press talk and six beeps occur. pressed bottom of base phone and nothing changes
  • Anonymous Nov 16, 2008
    I did have the same problem and taking the battery out for 1/2 hour worked. I also unplugged the base during that 1/2 hour. Thanks!
  • Anonymous Mar 22, 2014
    it wont register to the base, keeps saying unreg and when i try to reg it will not connect
Had the same problem with att cordless. would not connect.
I unplugged the base and repluged into wall receptical and
the phones connected. may take a minute.
Tom
Posted on Jan 25, 2008
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Posted on Nov 14, 2006
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
I require manual for Logik cordless phone
It is hard to find manual for a phone using the serial number of the base and hand units. Please check if the Logik phone is one of these models
L15DTAM10
L25DTAM10
L35DTAM10
The manual for these can be loaded from
http://documents.knowhow.com/Audio-Mobile%20Phone-Satnav/L15_25_35DTAM10_IB_A6_final100804_running%20change2.pdf
Aug 21, 2014 | Lands Phones
Why does my house phone have a dial tone, but the cordless ones do not?
Is the cordless phone base station connected into the phone line in the wall?
Aug 17, 2014 | Lands Phones
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
My house phone keeps saying bs search and wont call out or recive calls
bs meaning of course - Base Station...
There is no link between your cordless set and the base station, hence the message.
I would do what SpencerR stated, try to re-establish the connection via the base station to accept the handsets again.
Have the cordless sets worked before?
It may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless sets, and take out the batteries in the cordless set. Wait for about 15 seconds for all the power to drain out of the sets, and re-install the batteries.
This forces the base station to re-establish and link to the cordless sets.
Good luck
May 11, 2009 | Lands Phones
Panasonic KX-TG6071B - Feedback from base station
-Possibly the hands set is away too far and its base can't communicate.
Good luck & enjoy
Mai
Oct 23, 2017 | Panasonic KX-TG6071M Cordless Phone
Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Jun 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
Sony SPP-S2730 Cordless Phone Logo
2,612 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
