Question about Uniden TRU8885 Cordless Phone
Caller hear me from handset. can hear me when i am on speaker phone
I can hear the person on the other end of the line, they can not hear me from the handset. They can hear me when I speak on the speakerphone from the base. There is NO low battery light on the phone
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Posted on Jan 21, 2007
The helpers
SOURCE: handset not working
mike problem solution : Cange the mike of the handset
Posted on Oct 08, 2007
SOURCE: Uniden cordless phone - model DSS7855
Press and hold "end" and "#" for more than 5 seconds this will de-register your handset without the base unit.
see for more info.
Posted on Mar 05, 2008
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: The other party cannot hear me from one of the Uniden DCX 640 handset
don't hear with uniden 640 dcx
Posted on Nov 07, 2008
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
0 characters
1 Points
Can not hear dial tone or hear caller / can hear on speaker call
Most likely that it is the speaker on the handheld part of the phone. Your sound comes from the base itself when you put your current connection on Speaker-Call. So if you cannot hear the dial tone OR the person on the other end unless on "speaker" it's just the handheld and I believe there are places online you can purchase JUST that part if needed.
Oct 19, 2014 | AT&T ATT-1855 Corded Phone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
I can hear caller on handset but they cannot hear me?
We just had the same problem with our AT&T 2462 hand sets. They simultaneously stopped transmitting, and though we could hear the caller, no one could hear us on the other end of the line. We unplugged the base from the power source, took the batteries out of the hand sets, waited 20 seconds, then plugged everything back in and they worked just fine. Hope this helps.
May 03, 2009 | AT&T E2562 Cordless Phone
All users or just 1 or 2.
Have you tried to replace the handsets?
what kind of lines? Analog pots or digital PRI, or SIP?
Mar 16, 2009 | Avaya 4412D Corded Phone
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Jan 13, 2009 | Toshiba DKT-2010H Corded Phone
Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Nov 19, 2008 | NorStar M7208 Corded Phone
Caller can't hear my vocie when I use hand set
probly it fell or something the speaker needs replacing
Jan 04, 2006 | Vtech VMix Gz2456 Cordless Phone
Uniden TRU8885 Cordless Phone Logo
14 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
