Question about Akai DHT300 System
Dht 300 owners manual
Do you think you can possibly send me some of the important stuff from this manual, or at least let me know where i can find one online. I just purchased one on craig list, and it came with out one. Just one to know how to get started. and what plugs into where. Thank you for your time. By the way my email is tp1260@yahoo.com
Does this reciever offer optical connection?
There's probably a lot more you may wish to know. The manual and product sheet can be found here...
http://usa.denon.com/us/downloads/pages/instructionmanual.aspx
Use the 'Search by text' option.
Jul 05, 2011 | Denon DHT-683XP System
HI FixYa ,got a problem with my Denon DHT 500-SD . We were listening to the sound system ( it was on for about 2-3 hours).There was aloud pop sound and the system went dead .Is this a common problem? Is...
No, the pop was caused by the mechanical failure of a component - it got shorted or it has literally exploded. Because of that there is nothing you can do to fix it: the unit must be opened, tested, the failed part identified and replaced - all this must be done by a specialist, at a repair shop. You will have to send it to one, no way around that.
Jun 16, 2011 | Denon DHT500SD System
ON my new (used) Bose 3.2.1 II Audio system - it came with no manual and I would like to get a copy of a manual if possible and ALSO, more importantly, the radio doesn't seem to be working - it produces a...
Bose offers the manual in PDF format so you'll need Adobe reader (it's free from Adobe.com if you don't have it)...
http://products.bose.com/pdf/customer_service/owners/AM312515_01_321_SeriesIIIandGS_OG_ENGvo.pdf
As for reception; The FM antenna is a simple RCA plug, and you can make an antenna from an old headphone or speaker line...the AM antenna is a bit trickier.
You can also buy these directly from Bose at the following site:
http://owners.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/products/321_systems/dvd/index.jsp
* I would try eBay first to save a few bucks...
***Don't forget to VOTE for the guys who take an interest in helping!
Apr 19, 2010 | Bose 3·2·1 GS II System
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Denon DHT-500SD system and want what is on TV to come through 500
You could try the optical route. You should be able to use the analog RCA audio outputs of the TV to the analog TV or VCR audio inputs of the receiver as well. Select the appropriate input on the receiver and you should have TV audio.
Jan 02, 2010 | Denon DHT500SD System
Denon DHT-FS5 code c3 flashing, even after being unpluged for days. Unit does not respond to any imputs from the remote nor the on/off switch
I've got the exact same problem. It's an Overheating error, but I don't know if it's got a bad fan or temp sensor? Bad design?
Jun 27, 2009 | Audio Players & Recorders
I keep getting a messasge that says PROTECT on my Harman/Kardon receiver and then shts off
Disconnect all your speakers at the receiver, then turn the receiver back on. Turn on CD/DVD/Cable etc, then turn up the volume, if it does Not say "protect" you know the problem is in a speaker or a wire. If all goes well, re connect one speaker at a time with the receiver off, then turn on, turn up volume. Repeat until all connected or receiver goes back into protection. Once you find the bad wire/speaker, disconnect the bad wire at the receiver, then reconnect the remaining wires and test again. Now, disconnect the wire at the speaker causing the problem and reconnect it at the receiver. Make sure the wires are separated at the speaker side and; more importantly, cleanly connected at the receiver. If you have any freyed wires at the receiver, cut and strip, then twist the braid neatly. There should only be 1/2" of stripped wire, enough to fit under the terminal when you screw it down. Now, turn on the receiver and test again. If it does not go into protection, reconnect the speaker and test again. If it goes into protection at this point, you know its a speaker problem. If possible, disassemble the speaker to look at the internal wiring, if it looks good, look for a crossover network; this will look like a small printed circuit board. If it's really dusty, use some "dust off" and spray away the dust. look at the circuitry for visible damage, ie. brown or black spots. If you see them, there's your problem and the speaker needs repaired or replaced. To double check, you can meter the speaker for resistance. If your multimeter is digital and says 1..... it's a short. If it analog with a needle, it'll peg to the right. This is a very common problem. Hope this helps
Jun 11, 2009 | Audio Players & Recorders
An owners manual for a Denon AVR-2600 stereo amplifier
Hello, I found the exact web page for you to request your manual. Here is the link http://www.usa.denon.com/Product-Registration.asp Register your Receiver and then You can request the owner's manual, possibly in PDF format.
May 18, 2009 | Audio Players & Recorders
Password Problem / Possible Reset??
You can find the owners manual at manualfox.com - this should help.
May 08, 2009 | Amphion Mediaworks T342 System
Dht-5oosd home theatre system
I thought it was a free service in which case I would have been happy to inform you how I had solved the problem. However, as you wish to know to enhance your own skills and then charge for the service, especially one which I have aided in, I am left astounded at your ordasity
May 10, 2008 | Denon DHT500SD System
Akai DHT300 System Logo
Top Akai Audio Players & Recorders Experts
 Grubhead
Grubhead
Richard
Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
