Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Ethernet cable problem with my d-link
I have a major problem starting my pc. if i remove the ethernet wire before trying to start up all ok. but try booting with wire in and its a no go zone.
    Genius:
  • 1,689 Answers
There could be a possible issue with the lan card that you have, first thing you may want to try is to update the drivers for the card and if it is still not helping, please try to uninstall and reinstall the card in the computer.
for isolation purposes you may try another card of different brand on the computer and check if it will run or not. we dont want to look at a possible IRQ resource conflict, but at least we can isolate the issue and narrow things down.
Posted on Nov 05, 2008
Desktop pc windows 7 sp 1 wired cisco dpc 3008 no additional devices random connections
I would first get a new Ethernet cable and try it. If that doesn't fix it, call your cable company and have them do a diagnostic from their end. They can tell if it is their equipment or not. It their modem is OK, and the Ethernet cable is OK, then your LAN (Ethernet) card is either going bad, or possibly not completely inserted in the socket. To check: turn off and unplug your PC. Take the side off, look where the Ethernet cable goes into your computer. If it is on the motherboard, you may want to get a LAN card and use it instead of the onboard. If the cable goes into a card plugged into one of the slots, make sure it is fully inserted. If it is, you may want to get a new card.
Oct 28, 2017 | Cisco Linksys DPC3008 - cable modem
My router is not conact to network
The first thing I would suggest doing (to ensure you have a good connection) is to bypass the router, and connect directlyto your internet connection (whether it's a DSL through your phone company, ora cable connection through your cable company, you should have an incoming cat5 (Ethernet port) connection which looks like a phone jack, but slightlylarger.tgvern_8.jpg Remove the incoming jack on your router, and plug that onedirectly into your PC's Ethernet port . That should work OK as long as you have an active connection. If not, contact your provider and inform themof the problem. Assuming that works OK, then remove it from your PC, plug itback into the router, and while you'reback there make sure any other connections are also snug (they should "click" into place). A loose wire here will cause the "networkcable unplugged" message since the connection will be incomplete. I would also suggest to "soft boot" your router and cable modem(or dsl modem, as the case may be). Simply remove the power wire to the router and modem, and leave themunplugged for a minute or two. Reconnectthem both, and reboot your PC while you're at it. This will often solve many minor problems. If you are still having trouble, or if it works for a while,then starts to misbehave again, you may have a failed or failing router. Luckily these are pretty inexpensive, andfairly easy to set up depending on your security settings, etc. You can always post a new question if youhave specific questions regarding setting up a router, etc. I recommend using DLink or Linksys routers for most customers, but your cable/DSL provider may recommend a specific model for their customers. Good Luck!
Jul 25, 2011 | D-Link DIR-615 Wireless Router
Need help! Cannot access YAHOO and FACEBOOK,Thru tp link wired router (TL-R402M). Hope you can help me with my problem. Thanks! Jun Santos
try power cycle by removing the power of the router for one minute then plug it again. check the cable if all of it tightly connected to the specified port if it is a modem router it should have a 3 cable connected to it Phone line, Ethernet cable and the power adapter. the Ethernet cable should be connect to the back of your tower( computer). check you phone for a dial tone. check the light in the router like dsl , ethernet ,internet and activity. all of these must have a light.
Apr 14, 2011 | TP-LINK TPLink 4port ADSL2 Wired Route...
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
COMPUTER SHUTS DOWN
Possible solutions:-
1:) Faulty Ethernet Card or Slot on motherboard. Possible sharing violation.
2:) Faulty-Broken-D Cable.
Solution:- remove card, and insert into another vacant PCI Slot.
check cable for kinks or breaks.
Mike @ Compurepair.
Jul 23, 2008 | HP Pavilion A610n (PC106A#ABA) PC Desktop
Config DVMRe to PC
  1. Main Menu
  2. Communications
  3. Ethernet Settings
  4. Enable
  5. On your pc click start, run type in CMD, click OK
  6. at the prompt type in ipconfig, hit enter
  7. write down the ip address, subnet, etc.
  8. On pc open network connections
  9. create new connection
Jun 05, 2008 | Computers & Internet
LAN problem between Belkin modem and P5P800-VM MoBo
When you connect the pc to the router does the port number where that pc is connected is there any light on it? if there is check the IP address of the pc.
Click Start>RUN>type CMD click OK>type ipconfig on the command prompt if it says disconnected try changing the ethernet cable.
If you already receive a IP address that's good then try getting online.
May 03, 2008 | ASUS P5P800-VM Motherboard
No IP address
Try this link; http://www.anetforums.com/posts.aspx?ThreadIndex=29913
Oct 09, 2007 | Computers & Internet
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
