Question about Sanyo DS27510 27" TV
T.V. wont turn on
All the fuses are ok but the horizontal output transistor only has 57 volts, sounds like a low voltage power supply problem but i'm not sure what.
  • marty winslow Oct 11, 2006
    I opened the collector of the output transistor but the voltage is still 57. I dont think it is a problem in the yoke because the tv wont come on at all. It just doesnt seem to be getting high enough voltage to turn on.
    President:
  • 3,130 Answers
But my freind, If the set had a cold and hot chassis, it could be he is not measuring the voltage from the cold ground and therfore would be a normal reading?
Posted on Oct 10, 2006
    Sergeant:
  • 337 Answers
The voltage might be low because is being loaded down,open the collector of the output transistor and measure the voltage again,if it goes up to 130 or the voltage is suppose to have you might be looking at a bad output transformer(flyback)there are other parts that can cause the loaded down voltage,the yoke can be one and capacitors in the deflection circuit,check to see if one of this caps is overheated (bubble)or cook,Be carefull if you open the collector when you measure the voltage,If you can try measuring the voltage somewhere else.Lets Us know if you need meore help.
Posted on Oct 09, 2006
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
Sharp tv primo 21`inch turn on red light only
check your horizontal transistor maybe it's shorted replace horizontal transistor or maybe the fusible fuses are open check for open resistors at the horizontal section of the circuit.
Dec 22, 2010 | Sharp Televison & Video
No picture with sound
no high voltage. most problem is possible shorted horizontal output transistor. check collector of transistor. should be 135 volts dc. if not.... power supply or fuse.
Nov 13, 2009 | Televison & Video
Samsung hc-p4752w
look for trouble in the low voltage and or high voltage power supply circuits. the popping sound could be an exploded safety capacitor in the horizontal output to the flyback transformer. the horizontal output transistor maybe damaged. chances are the low voltage regulator is also damaged.
Aug 11, 2009 | Samsung HC-P4752W 47" Rear Projection...
No picture
I disagree with given info, this tv has no horizontal output transistor because it is dlp tv.
3 red light blink means lamp cover is not placed back properly after lamp replacement/ lamp checking. Make sure lamp cover is fixed back in its place securely and tight.
Jul 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Start up problem.
I suggest you look at the Horizontal output transistor, when it goes short the supply is in protection mode, it is pointless reading voltages at this stage, check the transistor located close to the Horizontal output (Flyback) transformer and normally mounted on a large heatsink. Check the caps in the primary power supply stage....hope that helps..Phil
May 19, 2009 | Televison & Video
Toshiba 57H81
Check all fuses in the power supply and look for any bad connrctions on the PCB. You are probably missing the 130 volt supply to the horizontal circuit. Common reasons are: Shorted horiz output transistor; flyback transformer, picture tube arcing , bad power regulator IC. In short, you need to get a qualified tech for this symptom. Hope this helps.
Oct 29, 2007 | Toshiba 57H81 57" Rear Projection...
Clicking sound, wont turn on
If the output transistor is good you need to measure the voltage at the collector to see if it has the needed voltage to operate,is also important to check the conections in the horizontal driver transformer and also measure the volts at the collector of the horizontal driver transistor,before you check any voltages check for loose conections and overheated areas,after everything is nice and solid then you can check for volts,be careful while measuring voltages and try not to touch anything with your bare hands while the set is on.Let us know how it goes or if you need more information.
Nov 07, 2006 | Sony KP-53V75 53" Rear Projection...
Question about the voltages.
what is the question please?
Oct 20, 2006 | Sanyo DS27510 27" TV
No power even standby LED..
This is like a car running without a driver,the horizonatl output transistor has the voltage it needs but it does not have horizontal drive signal applied to the base of the horizonatl driver transistor,the driver transistor should have a signal coming from the signal processor where the signal is generated just to get give it to the driver this driver then it gives it to the output to energize the flyback and light up the picture tube and generate a few other supplies,158 volts are there because the output is not turn on,try measuring voltage somewere else in the set and not at the collector of the output,there is a b+supply that goes to the signal processor(8 to 12 volts),check to see if you have this voltage,I couldn't tell you the pins in the siganl processor IC without squematic,It seems you know your way around tv service but be careful when checking voltages.Let Us know if you need more information.
Oct 10, 2006 | Samsung TXJ2067 20" TV
Sanyo DS27510 27" TV Logo
104 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
