Question about Sharp AL 1631 Copier
How to change sleep timer
I have customer who has a AL-1631 they used on a daily basis. The time out on the machine is happening way too soon . It takes about five minutes for it to warm up.
What is the service code?
  • Tim Babcock
    Tim Babcock Feb 15, 2009
    Sometimes that does happen in conjunction with the developer if the developer is low. On that particular machine it is automated. Some sharps have detailed setttings for controlling the energy star features. This is what I am looking for.
  • 29 Answers
I think the problem is the toner inside the cartredge is low so try to chek it.first
Posted on Nov 08, 2008
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
How do i keep the wifi on my epson wf2540 printer from going to sleep
  1. The Sleep Timer
    The product enters sleep mode if it is not used for a period of time. You can adjust the time period before sleep mode, but increasing the time reduces the product's energy efficiency.
    Changing the Sleep Timer Setting From the Control Panel Changing the Sleep Timer Setting - Windows
    Changing the Sleep Timer Setting - Mac OS X
    Parent topic: Product Basics
    You can use the product's control panel to change the time period before the product enters sleep mode.
    1. Press the [img src="file:///page23image5084" alt="page23image5084" width="15.095703" height="9.057693">button.
    2. Press the up or down arrow buttons to select Printer Setup and press the OK button. You see this screen:
& check the manual page 23 https://files.support.epson.com/pdf/wf2540/wf2540ug.pdf#page23
Sep 05, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
Worn -out gears
I recommend and use precisionroller.com on a regular basis. In your case you can just type in al1631 gears in the search box and it will give you a list including pictures of most parts. I have worked on hundreds of these machines so if you need further assistance just ask.
Thank You for using Fixya.
Jun 15, 2010 | Sharp AL 1631 Copier
Noises on power-up.
emty waste toner and clean
Apr 22, 2010 | Sharp AL 1631 Copier
COPIER KEEPS GOING INTO SLEEP MODE, CAN THE MODE BE DISCONNECTED?
The default timer for sleep mode might be set to fast...
U can try adjust the timer according to your manual.
Sep 29, 2009 | Sharp AL 1631 Copier
My AL 1631 cycles on, light comes on but won't move or copy
Toner is running low. Light come on to say the machine is adding toner. Soon it will come on and stay on.
Jun 08, 2009 | Sharp AL-1655CS Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Dec 01, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
117 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
