Question about Maytag MGR6775 Stainless Steel Kitchen Range
Oven Problem My lower oven just started to do the same thing as yours. Did you ever discover a solution?
    Problem Solver:
  • 7 Answers
Yes, I replaced the lower oven sensor: it did not have continuity once disconnected from the rest of the circuit. That sensor transfers the power to the lower bake ignitor.
Posted on Nov 16, 2008
I need some parts replaced
If it's a brand name and less than 7 years old you can see if parts are available by googling the brand name including the model number & the word parts. Don't be surprised if the parts & shipping cost more than the oven. Good luck. The voice of experience.
Aug 24, 2015 | Toaster Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Sep 26, 2009 | Ovens
Door hinge locked up.
Discovered a faulty hinge and will replace it.
Aug 23, 2009 | Frigidaire FEB30S6D Electric Single Oven
No heat generated in lower oven
You are quite correct in saying that the element has failed.
As regards the wattage , it should be stamped on the fixing plate of the element, if you cannot see it there then opt for the lower wattage one, it will not make much difference to the oven ,as there is only100watt difference between the 2., and that is nothing to worry about.
Plz rate my solution to your prob.
Thanks.
Jan 03, 2009 | Neff U1721 Double circotherm Electric Oven
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
GE double oven - bottem will not heat, top oven fine
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
Good Luck, DVS1936
Oct 05, 2008 | GE JKP45 Electric Double Oven
Frigidaire non-digital (old) Caprice top electric oven not working
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
Jan 21, 2008 | Frigidaire 27 in. Electric Double...
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
Open Questions:
Maytag MGR6775 Stainless Steel Kitchen Range Logo
168 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
