Question about Consew 226R-1
Tension I am having the worst problem with tension (upper or lower or both) plus thread breaking. Just changing the thread causes tension issues and / or thread breaking. After a lot of time adjusting, the tension works well until the next time I have to change thread or bobbin. My thread is bonded polyester and the size 18 needle. Is this machine heavy duty enough to handle canvas/vinyl?
  • 26 Answers
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Posted on Aug 31, 2009
When sewing a straight stich The bottom thread is loose.
Your upper and lower thread tensions are out of balance. The upper thread tension is too high or your lower thread tension is too low. Make sure your bobbin thread is correctly routed under the tension spring. There is a small screw on the bobbin case that always you to adjust tension.
Feb 20, 2017 | Sewing Machines
Can incorrect timing adversely affect lockstitching tension balance, causing totally intractable tension issues?
Timing can affect a lot of things. However, there are multiple things that will present problems. Even the tension disks can be dirty or not working properly.
Usually the most common problem--the machine is threaded incorrectly. The best practice is when a thread breaks, comes unthreaded or is malfunctioning, remove all the thread and rethread from the beginning. First RAISE the presser foot before threading so the thread will seat properly in the tension disks. Check to make sure each thread is threaded in the correct order or the machine will most likely never work well.
Jan 28, 2016 | Sewing Machines
How do I determine what tension to use?
Tension setting is trial and error. To learn choose two color threads same weight and manufacture. placing one in bobbin other top tread.
Set the lower tension to light. The lower tension has always been lower than the top.
Depending on needle size and material the upper needs to be set.
Use the images as a guide.
26050009-gmetzlbygkf20izcnwtcwtjv-4-2.png Hope this helps?
Jan 12, 2016 | Sewing Machines
So when I start sewing it works for a few seconds then my top thread breaks and or wraps its self around the black casing the bobbin sits in. What am I doing wrong?
Be sure to RAISE the presser foot BEFORE threading the upper thread. This releases the tension disk so the thread can seat properly. If upper thread is breaking soon after beginning to sew, it usually is because the upper tension is too tight. Try loosening it and re-testing. The upper and lower threads should meet in the middle of the fabric.
Sep 21, 2015 | Singer Pixie Plus Sewing Machine
The needle thread keeps breaking, I'm using good quality thread and have tried re threading and changing the needle but it still keeps breaking, any advice would be most welcome.
1. Set the tension on the bobbin.
2. When you thread the upper thread do it with the pressure foot up.
While you are threading give slight tugs to check for snags. If there are snugs you must fix them.
3. Put the pressure foot down and adjust the tension to four. Give a tug. It should have tension but still allow the thread to flow.
(Look at your thread and look for fuzz on the sides. This indicates a bad quality thread. A good choice is embroidery.)
4. Make sure the needle has been installed going the right direction. Usually flat to the front or to the right side.
5. Turn the hand wheel while you hold the needle thread to the front.
The bobbin thread should come above the throat plate in about one turn.
Jul 23, 2015 | Sewing Machines
My thread keeps breaking after I sew just a little bit. I have changed thread, check it is put on correc. Please advise. Not sure if I have the top tension correct.
1. While threading put the foot up.
2. Give gentle tugs along the way. It should be without feeling any hangups.
3. Wherever the hangup is you must correct. Usually at the tension disc.
4 Sometimes the tension disc is tightening more than the indicator says. It should be about four. You can lower this tension setting until the stitch looks good.
5. You may have to take the tension assembly off and clean it thoroughly and sand any rusted spots.
May 30, 2015 | Sewing Machines
Brother pc 8500 upper thread breaks
Check the spindle the thread is mounted on and see if it\'s wrapped around it. Sometimes thread will catch and wrap around the spool spindle and break.
Check thread guides to be sure there are no nicks that might be catching the thread or damaging it.
Replace the needle.. a burr in the eye can cause upper thread to break. Needles should be replaced often, modern fibres can be hard on them, they get dull and that\'s no help for anything either.
Make sure the thread spool is mounted on the spindle with the thread coming off as directed in the manual. Some machines only work when the thread feeds in the right direction from the spool.
It can also be a tension issue.. tight upper tension or tight bobbin tension. Bobbin tension may be adjustable manually, but it\'s pretty rare for it be a problem. Upper tension, I don\'t know. I\'ve yet to get into computer machines so am not familiar with how they set upper tension.
But the mechanism that produces the tension can wear out or break and need replacement.
Jun 25, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Why is my bobbin thread tangling and binding up under the plate?
Check tension levels of both upper tension unit and bobbin case.
With machine threaded, pull the bobbin thread. There should be some tension/resistence. Lower the presser foot. Pull on the top thread. Again you should feel some tension/resistence. If you don't feel any, raise presser foot and test upper thread again. If no difference, it is an issue with the upper tension disks. Brush out any loose threads that might have gotten caught in the upper tension disks which is causing the disks not to close. If there is no difference with presser foot up or down and no threads in tension unit, the tension unit will probably need to be replaced. You should have the machine serviced at the local authorized husqvarna viking dealer. You can find the nearest dealer at the husqvarna viking website -
Apr 27, 2014 | Husqvarna Sewing Machines
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Consew 226R-1 Logo
807 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
