Question about Panasonic PT-AX100U-EC DLP Projector
Distance from projector to screen
Please tell me the minimum distance required the projector and screen have to be. Thank you
  • 4 Answers
I need to know what screen size you are looking to get and the dimensions of your room
Thanks
Jordan Thomas
Port City AV
910 538 2754
Posted on Dec 07, 2009
My projector dont show fuii screen,it show pictur but no full size
Couple of things here. Is the projector at the proper distance from the screen? (aka throw distance). If it as at the proper distance from the viewing surface then, if available, check and use your zoom.
Aug 22, 2014 | Office Equipment & Supplies
I have a question regarding the distance I can achieve with the Dell
The Dell 2400MP Projector is rated for 1-2 to 12 meters, or 3.9 feet to 39 feet.
However, the farther the distance to the screen, the dimmer the image will be.
A great resource for Dell Projectors is this link: http://www.projectorcentral.com/Dell-2400MP-projection-calculator-pro.htm
It leads to a little flash tool that allows you to use sliders to adjust throwing distance and then tells you how much light you can expect the wall. It also gives you a ton of other useful information about the projector.
hope this answers your question
D.
May 02, 2011 | Dell 2400MP DLP Projector
What is minimum clearance between top of the range and the top of the SMH9187 microwave?
If you live in the USA, the minimum distance is what ever your local condtruction office building official says it is. If there is no local code, they will tell you what the national code requires.
Please give that office a call and find out what your local sode requires for minimum clearance.
Thank you for your interest in this website
Feb 02, 2011 | Samsung SMH9187 Microwave Oven
Projector to screen distance
hi,
minimum distance is 2 meters (projection 41 inch)
maximum distance is 13.4 meters (projection 300 inch)
ok
Jan 06, 2011 | Sanyo 6102607208 Projector Lamp for...
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
I moved to a new house and the image does not fill the whole screen like before i already ck the zoom on the lens
I'm sorry,but the product cannot project the required size from the current distance from the screen,I tend to use a short throw lens projector for this.
May 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
Focus problams
if the power focus is not moving, the motor might be siezed and need repair or replacement. also make sure that the resolution matches the source. the projector is designed to have a minimum throw distance of 7.8 feet. if your screen is closer than that, it won't focus. if the motor works, the resolution matches, and the distance is ok, then you need to clean out the dust from the projector with canned air. if that doesn't help, you have an optical engine issue caused by excessive heat. either the light filters or the fly-eye lens are burnt and need replacing.
Aug 10, 2009 | Epson EMP-835 Multimedia Projector
Size of Projection
Hi Jez
Distance is definitelly your problem here - the lens can only reduce so much. You will have to move the unit.
Nov 30, 2007 | Optoma H30 Multimedia Projector
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Panasonic PT-AX100U-EC DLP Projector Logo
327 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
