Question about Mitsubishi Televison & Video
Our 2 year old 52" HDTV (Mitzubishi)
Our TV is on it's 5th new lamp, and has had to have the thermal sensor replaced as well. After the sensor was replaced it took 8 months to burn out a lamp, as opposed to every 4 months.
  • 85 Answers
Hi there.im not familiar with your actual set,but i assume it uses a metal hallide lamp,which,on average do around 2000 hours of use.lamp life is crucial to the cooling system,usually a fan.its paramount that this is working,and that the air intake filters are clean.the thermostat only ever fails due to the lamp overheating.which means the cooling system.most likely the filters,externally removable.regards,steve
Posted on Nov 05, 2008
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
The tv is only 4 years old and just stopped working while we were watching it. it is a "52 model number pt-52lcx65-ka.
If lamp in tv has not been replaced in last 3-4 years then check lamp and replace it.
Did tv showed lamp replacement requires warning/ message on screen before going to shut down?
Did you hear any pop sound inside tv when it get shut down? that pop sound could be lamp that got broken.
Let me know if you have additional question.
Thanks.
Feb 27, 2011 | Panasonic PT-52LCX65 44" HDTV
Red light came on indicating the lamp.And it keeps cutting itself off
The projection lamp has not been replaced in this tv like 1 1/2 or 2 years?The tv projection lamp life are over.Require a new projection lamp.
Oct 06, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Picture turned to red then picture disappeared. voice can still be heard. lamp light not on.
The projection lamp is dead.The tv projection lamp in the tv now,been in the tv like 1 1/2 or 2 years,The lamp life span is over. Require replacing a new projection lamp.
Aug 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How do i know i need to replast my lamp.. my tv is 2 years old.
your T.V will not turn on and the lamp light will be blinking meaning that ur lamp needs to be replaced
Jan 30, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Nov 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
How do I test the Lamp Thermal sensor?
Good Day;
The indication that the sensor is bad is showing the "air flow message", not an item that can be tested with positive results. Replace, it's only a couple of dollars. Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 52hm95 52 in. HDTV
just take out the old one and replace the new one
Sep 23, 2008 | Toshiba 52HM95 52" HDTV Projection...
Televison & Video Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
