Question about Remington Electric Pole Saw
Remington Pole Saw Model 106890-02
After some heavy work, motor slowed down, then only buzzes, does not turn. Is the cost of repair (replacing the motor) more than the cost of a new saw?
  • Anonymous Nov 09, 2008
    Same problem here. Chain binded on a 2 in brach, now ineternal clicking sound. Tore apart, found ring gear stripped..Motor/pinion gear appears ok. Emailed Remington for replacement parts...No reply.
    Good luck.
  • 211 Answers
Hi
if you were used the correct oil-gas mixture,because of overheating the engine probably you need to change the piston ring.Check the piston first(take off the mufller and take a look,if there are screaches at the piston is not good).
regards savumihai71
Posted on Dec 02, 2008
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Trouble starting
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Apr 19, 2014 | Remington Electric Chain Saw
Extremely weak motor model 108526-01 remington
Feb 12, 2014 | Remington Garden
Are brushes available for remington 106890-02
Nov 06, 2013 | Remington Electric Chain Saw
Where can I get brushes and at what cost?
Parts for Remington saws are few and far between. Brushes are a common failure point and those available have about been bought up. You best chance is to check with a well-stocked hardware store or an electric tool repair shop for a similar brush from a different tool. You may have to modify something similar to fit. Good luck!
Dec 11, 2010 | Remington 111409 - 01 6" Branch Wizard...
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Jun 28, 2010 | Remington 16" Electric Chain Saw
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
Remington pole chain saw model 106890-02. Chain
We are in no way connected with RemingtonPower. They are no longer in production and replacement parts are very difficult to find. Often eBay is your only source of parts. Sorry. Lou
Mar 16, 2010 | Remington Electric Chain Saw
Where can I find a replacement locking nut for the pole? For 10" Remington pole saw
Without the model number, I can't provide you with the part. However, you can go to masterparts.net and click on the Remington chain saw link and with your model number, get a line drawing and list of all available repair parts and pricing.
They have almost all the parts for even most discontinued Remington chain and pole saws and have a toll free number you can call, once you have your model number to provide them with. 1-866-672-6040
Hope this helps and best regards!
Jul 31, 2009 | Remington Electric Pole Saw
How to attach chainsaw to pole
I am not sure what model number you have, but here is a link the owner's manual for model # 106821A ... http://12.153.20.74/manuals/111219-01B.PDF. On page 15 of this owner's manual explains how to attach the pole to the saw. Just make sure you are attaching the saw that is made to fit the pole or it may not work or be to heavy for the pole. I hope this helps.
Jun 06, 2009 | Remington Polesaw Wizard
Remington Electric Pole Saw Logo
1,211 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
