Question about Kenmore 65924 Electric Dryer
Removing engine i have a kenmore dryer movel 66512690 and am replacing the motor - got everything disassembled but now can't pull the motor out cause it is locked in at the back - how do i get the engine out HELP
I need to get the back off of my LG gas dryer. I need to convert it to LP. I have the conversion kit, but can't get the back off the dryer.
Posted on Apr 26, 2009
  • lfromhertz Apr 26, 2009
    I took off every screw, it still won't come off.
    what clamp
  • 547 Answers
Open back take off clamp
Posted on Feb 12, 2009
4 Suggested Answers
SOURCE: kenmore dryer not spinning---how do i disassemble to see if belt or motor is bad?
kenmore dryers are the easiest dryers to work on. unplug! remove 2 screws @lint screen top. insert screrwdriver under top @ each end and pop top up. disconect wires to door panel. remove 2 5/16 screws at each end inside. lift front door panel up and out.( the bottom of the panel is held by spring clips. replace belt if broke. remove drum if not and check rollers. note: belt route at idler pulley.
Posted on Jul 19, 2008
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer- remove fan to change motor on
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Posted on Mar 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
I have a Kenmore 66512690 dryer , when i press the start button, I just get a buzz like it wants to go but it does not. Could this be the motor?
Based on the limited details the motor is either humming instead of starting and running or the motor is running but the drum is not turning.
This symptom could indicate:
  • Broken belt if it's blowing air out the exhaust.
  • Faulty motor
  • Jammed drum
  • Loose wiring connection
  • Object or piece of clothing article jamming the blower wheel.
Open the dryer door and see if you can rotate the drum in a counterclockwise (CCW) direction. If it's very difficult to rotate then it could have something to do with the motor or drum glide. If the drum will not turn then something is likely jamming the blower wheel.
Jan 08, 2011 | Kenmore Dryers
My Kenmore 66512690 dryer will not heat up or dry cloths. The drom rotates and the motor seems fine.
check your fuses in your panel. If one is gone the dryer won,t run if the other is gone it just won't heat
Oct 27, 2010 | Dryers
Roper dryer movel RED4440vq1 drum does not turn. replaced motor, still not workking. belt is good. wiring harness is supplying 120 v on the 2 end red leads. door switch good. push to start button good.
The thermal fuse is likely blown. Disconnect power then remove the rear panel to access the thermal fuse on the blower housing.
Once the panel is off, bypass the thermal fuse by joining the wires together then insulate them properly. Reconnect power and start the dryer. The thermal fuse is indeed blown if the dryer starts. Replace it including the cycling thermostat.
Oct 15, 2010 | Roper Dryers
How remove front panel of frig gas dryer faqg7077kw
Hello there:
Here is how to disasseble the dryer
White/Westinghouse - Frigidaire style dryers- How to take apart....
White/Westinghouse, Frigidaire style dryers ( some 417.######## Kenmore dryers ) - How to take apart:
Disconnect power first In order to test and effect repairs on any product, you must be able to disassemble and reassemble the appliance. So lets start with disassembly on this dryer. Unplug the dryer. Get the top up by pushing in on 2 clips on either side as shown in this picture. We need to remove the front of the dryer next. There are 2 or 4 screws inside at the top on most of the older dryers that we need to remove. Once the screws are removed, you can pull forward on the front and lift the complete front off the 2 clips on the bottom of the dryer. Unplug the door switch wires and set the front aside.
if you need to further dissassemble it follow the next steps
Next step in disassembly is to remove the belt from the idler and the motor pulley. This is done at the rear of the dryer. Remove the 2 screws holding the inspection plate on the left rear of the dryer. Remove the plate. Look carefully at how the belt threads around the motor pulley and idler pulley so you can replace it. Remove the belt from the motor pulley. Return to the front of the dryer, grasp the belt in one hand and the front of the drum in the other hand. Lift up on the rear of the drum and pull forward with the other hand. There is a ball on the rear of the drum that rides in a socket located in the center of the back of the dryer. You are lifting the knob up and out of the socket. Look in the center of this picture for the socket. You have taken the dryer far enough apart at this point so that you can accomplish any repairs needed on this style dryer. It is not necessary to go this far for all repairs, but if you need to disassemble, you have the information.
Jan 09, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have a Kenmore 70 Series electric dryer #66702 that stops before the end of the cycle time. It will start up again after pusing the start button but may turn itself off again after a few more minutes....
This is usually caused by a motor getting too hot. The motor has a shutoff to protect it against burnout. It will reset when it gets cool. As the motor overheats more and more these shutoffs become more frequent and longer
Motors get hot for several reasons:
1. Motor going bad
2. Lint around motor causing it to retain heat
3. Vent system open at some point inside or behind case allowing heated air to remain in motor area
Follow the procedure below to disassemble and check interior of dryer. Vacuum carefully especially around and in the ends of the motor.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dryer will be on right.
Sep 10, 2009 | Kenmore 65942 Electric Dryer
Kenmore 66512690 problem
Appliances which use heating elements almost always have an internal overload protection switch. This overload usually looks like a small diode or resistor somewhere on your incomming power inside the machine. Try to find this overload and bridge it out and try the machine again. These overloads usually have a rather limited life span and are most often the cause of a "dead" machine.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore 65924 Electric Dryer
Kenmore dryer
It is very much easier to replace the belt from the front, than the back, the cabinet disassembles from the front, and the mechanism remians attached to the rear plate and cabinet floor.
  • pull lint filter out
  • remove 2 screws from under lint filter
  • with putty knife or other blunt blade, release clips at front corners of cabinet top
  • tilt up cabinet top
  • remove 1screw 1/3 way down each side of front of cabinet.
  • lift off cabinet front
  • drum, motor, tensioner, are all exposed
  • lift drum out forward
  • check rollers, drum felts, nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage and you dont want to do it again next month)
  • reinstall tensioner in slots in cabinet floor, reinstall tensioner spring between tensioner and cabinet floor
    (Once the cabinet is open the tensioner mounts are easily visible)
  • loop belt around drum at the wear marks of the prior belt
  • reinstall drum on unworn bearing rollers etc
  • loop belt around motor pulley
  • pull tensioner hard against spring to end of travel
  • loop belt around tensioner
  • relax tensioner
  • spin drum by hand to ensure belt isnt going to jump off
reinstall cabinet in reverse order
~15 MINUTES, but I do 3-4 per day
Oct 07, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer not spinning---how do i disassemble to see if belt or motor is bad?
Jul 19, 2008 | Kenmore 75944 Gas Dryer
Kenmore 90 seies belt replacement
you have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
Apr 05, 2008 | Kenmore 65924 Electric Dryer
Kenmore 65924 Electric Dryer Logo
133 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
