Question about Kenmore 44102 Front Load Washer
Weird smell I have a Kenmore 44102 washer. It's recently started smelling of cigarette smoke. And we don't smoke! That's the best way I can describe it. At first it was only when opening the door. Now it seems to be all the time when running. Any suggestions? Thank you!
Probably mildew. They often suggest running a bleach only (no clothes) cycle every month or so with front-loading washers.
Posted on Jan 27, 2007
SOURCE:
E-cig -So how exactly does This Function?
One of the latest products which created this towards the market place concentrated in assisting individuals quit their own cigarette smoking routines would be the e-cig or even e cigarette. In addition, e cigarettes can help you people who smoke and as much as 1000s of dollars each year. Here details on:-
Electronic Cigarette Canada Voted Best Electronic Cigarettes in Canada...
Sep 08, 2014 | Health & Beauty
How to get smoke smell out of wood furniture
it's probably an electronic cigarette. you can get loads of different flavoured liquids to put in them.
Aug 03, 2014 | Health & Beauty
How to get rid of cigarette smell in car vents
Use air fresheners to eliminate smoke smell. After cleaning out the car, raid your pantry for odor eliminators. Dryer sheets placed under seats will help freshen the air. Also consider putting an open box of baking soda or a bowl of kitty litter in the car to absorb cigarette smell
How to Get Cigarette Smoke Smell out of Car
Apr 11, 2014 | 2003 Chevrolet TrailBlazer
Persistent mold and mildew smell, even though door is kept open and I live in an arid climate. Any solutions?
every front load washer evetually will start to smell,the best solution ls run your washer with hot water and put a container of clr in the washer it will wash all the residue built up on the outer tub
Mar 30, 2010 | Kenmore 44102 Front Load Washer
It is not putting a good smell in my home, It smells like cigarette smoke. I have a classic air purifier, and a newer model with ultraviolet light. They both do not put a good smell, in fact the one in...
Hello, To smell like cigarettes, you would have to be smoking ? I would recommend calling the manufacturer and describing this problem to them. Somethings going on, and I would start there. I hope they can be of help to you.
Good Luck, Shastalaker7
Nov 04, 2009 | Ecoquest Living Air Classic Air Purifier
Weird smell from refrigerator
Is the smell from inside the refrigerator or on the outside? If outside, it is possible a humid smell from the condensate drainpan water evaporating. You could put a very small amount (a couple of granules) of pool chlorine in the drainpan.
Mar 03, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Smoke smell coming from my 80 series Washer
do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Dec 02, 2007 | Kenmore 15864/15862 Top Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44102 has stopped sudsing
Nancy this is a hard one. The first thing I would do is check how hard your water is. The harder the incoming water, the less suds. I believe your model starts with a 417. front loader and I assume that the detergent is being dissolved in the disp. tray. On this model, most of the water will be under the basket while agitating. Now, your drain from the tub has a filter and if it full of lint and debris, it could be restricting the drain, leaving dirty water in the tub. You would have to remove the lower panel and check the tub filter. This is located in the tubing coming down from the tub going to the trap and pump. I will attach a photo for you. You can also run the washer empty with hot water. Add 2 cups of bleach. After it starts agitating, stop it and let it sit for 2 hours. Then resume the wash and let it finish. See if the dirty smell goes away. Catriver..post back
Mar 19, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
171 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
