Question about Radio Communications
No receive on AM side works great on SSB
The radio transmits fine on the am side but no receive?
  • cqdx Nov 05, 2008
    The Radio is a ROYCE I-632 40CH PLL AM/SSB mobile cb radio
  • 204 Answers
Hello cqdx, wow, where do I start??? That radio is about 30 years old, and a lot of changes have taken place on the circuit board componants. Not to mention that the Royce line of radios were not of the best quality even when they were new. Probably you have a solder joint problem or a cap or resistor has changed value. Really not worth the time to troubleshoot and repair. As a tech, I would much rather spend the time on a good quality radio to repair, and not something that will be back. Just my opinion, as a 10 year tech. Mechanic
Posted on Nov 05, 2008
Why is there no transmit modulation?
'mic gain' adjusted for optimum amount of modulation?
Oct 15, 2015 | Radio Communications
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Yaesu ft-990 no receive or transmit
Lynn, SSB (Single SideBand) only applies to AM (Amplitude Modulation) transmission. There is no way to broadcast SSB in FM (Frequency Modulation) mode.
May 16, 2015 | Yaesu Radio Communications
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Receive is ok, but when I transmit on SSB the Freq. jumps 10KC. What adjustments can I do to get the transmit back on Freq. without effecting the Receive?
go to you tube and type in your radio make and model and watch the review on that radio there is a freq adjustment pod for ssb adjustment. they might tell you if not take it to a radio tech and he should be able to alighn it. there is more than one pod for ssb transmitt and receive.
Mar 21, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Only side band receiver no am on 148GTL
Radio works on SSB but not AM?
Question here is it loss of transmit only on AM Receive?
If receive is good but no transmit on AM---I can tell you what transistor is bad
SD TECH
Sep 28, 2010 | Televison & Video
SSB radio
If you are using the radio on a boat, then no, the grounding does not matter that much. However, an SSB transceiver would be hassle to install on a boat because of the amount of power they use to transmit. If the transmission is bad, try using the radio's internal tuner instead of the separate tuner. This may help improve the quality of transmit, however, some radios have a tough time clarifying incoming and outgoing signals and create a garbled sound when it receives a signal or when it transmits. If that doesn't work, then you can try grounding. But if you want a radio that doesn't require all this nonsense tning, you might want to think about investing in a Yaesu. They are pricey, but are one of the best HAM radios.
Sep 04, 2008 | Ranger TR-696F SSB CB Radio
No AM carrier or modulation. SSB transmits good
what cb is it ? it sounds like your am section is not getting powered up when you switch from ssb to am. If i know the model i may have a diagram of it here and suggest a place to start
May 02, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
90 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
