Question about LG WM1814CW Front Load Washer
Internal Smell the washer is years old and inside it has developed a smell like sewer gas. The smell gets on the clothes. We have no apparent plumbing problems and the unit appears to work just fine otherwise.
I had the same problem especially in the summer time when the heat and humidity are high. ( I live in the south) The solution I have come up with is to keep the space between the wide rubber piece and the hard plastic piece that encircle the opening cleaned. It can be a pain to do because I am always afraid I am going to damage the rubber piece. I use a 1 - 12 solution of clorox and water and a soft cloth and a soft toothbrush for the ridged places. I also leave the detergent dispenser tray open when I am not using the washer so it can dry out. This has really helped me.
There is also a product that I have seen that is made just for this purpose. I saw it at Home Depot one day. It is probably available in the detergent aisle at other stores too, I just have not looked for it. I refuse to buy a product that is made to correct a defect in design. My clorox and water treatment works just fine for me and is much less expensive.
Posted on Nov 14, 2008
I have a bathroom sewer smell that appears to be from the sink. I have had the lines snaked out and it is better but still occurs. We have old cast iron plumbing 1950's house
Most probably it is because the ventilation pipe on the sink is not exhausting the methane gas properly, so the methane/rotten egg smell is coming out of the drain. Sometimes if vent pipes are not angled properly, the gas/smell will not rise properly. If there is no ventilation pipe hooked up to the sink, you will most probably smell it. Good luck.
Jan 11, 2018 | Washing Machines
I occasionally have a sewer gas smell near my washer. But after I run the washer, the smell will go away for a few days. What could the problem be?
Hi Joe
Is that pex pipe on the right your water supply to the washer?
Your sewer gas smell I believe can be eliminated by putting a P trap in the drain PVC line.
(EDIT)
Where the drain hose from the washer hooks into the PVC pipe is NOT airtight which would allow the sewer gas back into the laundry room!
(EDIT EDIT)
If there is a P-trap in your outflow pipe, the only place left for grey water to collect (and stink) would be between the washer and where the waste hose goes into the drain. We've had to use a little bit of bleach on occasion when we haven't used the washer for a bit.
Hope this helps
-Steve
May 02, 2015 | Maytag Neptune Washing Machines
Sewer smell in clothes
The tub is probably pretty dirty. Try cleaning the washer with CLR.
Visit this information:
http://www.ehow.com/info_8053120_clr-clean-washing-machines.html
Mar 19, 2014 | Fisher and Paykel GWL11 Top Load Washer
Smell of sewer in the house
Ensure all your additional rough in plumbing is capped, and toilets or sinks that are not used for long periods of time , sometimes p traps may dry up allowing sewer gasses to enter the home so use them once in a while or fill with water once in a while ,same with floor drains. If that isn't it check that you have them installed.
Jan 06, 2014 | Northstar Sewer And Drain Cleaning...
I have just remodeled a old condo with new toilets and I am getting a strong gas smell. How can I get rid of it. I am in Thailand and the building is 22 years old.
jajoy,
Did you connect the sanitary pipe stack to the sewer line that takes away the flushed effluent? Check to see that the pipe is connected, not leaking sewer gas, not plugged up with an animal carcass, and that the pipe extends through your roof three feet past the roof line (keeps smell out of house).
Nov 29, 2010 | Air Purifiers
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front load washer SMELLS!!!!
your inner tub needs to be removed and the outer tub including the outside of the inner tub needs to be cleaned of all the sludgy soap, fabric softener,etc. that has built up in between the tubs,along with the drain tube at the bottom,you might try bleach as a stop gap,but sooner or later you are going to have to clean this out the hard way,its not fun
Mar 09, 2010 | Washing Machines
When machine pumps out the smell comes through the sink
All plumbing drains whether under a sink or the stand pipe drain, for a washer, are required by LAW to have a trap to prevent the sewer gases from entering a home.
Sewer gases are dangerous in many ways, not the least of which is the terrible smell. Sewer gas can build up and if allowed to accumulate near an appliance that operates on gas (LP or natural) can combust and cause a fire and/or an explosion.
Yes, if you can do the installation youself, do it ASAP, or contact a licensed plumber and have installed a proper drain trap for the sink and also make sure the drain that the washer is draining into, also has a trap in it.
This will have a profound impact on the smell and will help alleviate foul odors from your sewer lines.
Hope you found this Very Helpful and best regards!
Sep 22, 2009 | Whirlpool AWM5145/2 Front Load Washer
LG WM1814CW Front Load Washer Logo
136 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
