Question about Husqvarna Viking 1
I keep getting an "thread is empty" sign when it isn't.
I have a husqvarna 955E and after a few stitches an E will flash and the machine will stop sewing. This is the sign that the thread is empty and it's not. I have re- threaded the machine several times, changed the needle, changed the bobbin, turned the machine off and let it reset and unplugged it. nothing helps. I would appreciate any help I can get.
Thanks,
Michelle
  • No2more Nov 05, 2008
    I have the same machine and have received the same message.. The E is an error message, not thread is empty. Something is causing the error message and it could be the tension of the thread. You have checked the most common reasons, now check to see if it is bunching up underneath or if you are using the proper thread.. Are you using the proper needle? Is your bobbin threaded properly? Normally those will solve the problem.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Sounds like the thread out sensor needs to obe adjusted. It is around the takeup lever. What the bottom area between the tension and take up lever to see where the spring pulls up slightly when the thread becomes taunt. Probably close to the tension adjustment dial. The spring needs to be adjusted--probably down slightly. I would recommend taking it to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner typically. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
What could be wrong with my Husqvarna Mega Quilter?
could be the computer is not working right or could be a mechanical problem, if the problem doesn't stop the machine needs to be checked
Jan 06, 2016 | Husqvarna Sewing Machines
Machine keeps saying recheck/rethread upper thread
sounds like the computer motherboard could have malfunctioned
and needs to be checked
Nov 21, 2012 | Brother InnovIs 4000D Computerized Sewing...
Husqvarna 415 sews few stitches then stops
could be a safety switch problem
try changing the needle
rethread the machine top & bobbin--use every thread guide
clean under the needle plate & in the bobbin area for lint
if the problem persists the machine may need to be checked
Sep 13, 2012 | Husqvarna Freesia 415
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Have a Husqvarna 870 Quilt sewing machine. Ever since I got it two years ago I have had trouble with the thread take-up lever becoming unthreaded as a stitch. Sometimes this will happen after only a few...
you can put a piece of tape on it to keep the thread from coming off
or as one service tech showed me, take a pair of pliers & put a small cloth over the thread take up
lever & take the pliers & gently mash down the take up lever closed or as much as need to keep
Aug 08, 2011 | Husqvarna Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Husqvarna 955E will not change stitch length. Is
Does the length on the display change or is it as if the buttons are not even working. If the touch pad is malfunctioning you will probably find other buttons not working. Try all of the buttons and see if others do not work. If this is the case, the keypad can be replaced.
Sep 02, 2009 | Husqvarna Viking 1
Thread is not broken
Take it back to the service centre with your samples....phone to arrange a time to meet and show them how it sews when you are in the shop.
Aug 29, 2009 | Sewing Machines
After a few stitches my machine quits
The problem you are having is with the sensor on the top tension unit. There is a sensor that registers the movement of the spring which lets the machine know that it's sewing. When the spring either sticks or the sensor moves out of position because of vibration, the machine "thinks" that the top thread is broken. The machine needs to be taken apart and the top tension spring checked to see if it still has enough pressure to return to it's starting position, or to see if the sensor is in it's correct position. A trip to your service tech is required
Jul 04, 2009 | Husqvarna Rose
Sewing Machines Logo
65 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
