Question about Kenmore 63672 Convection/Microwave Oven
I have an admiral microwave model 8573
Cannot figure out how to change the light bulb....doesn't show it in the manual...help... thanks
  • dana obrien
    dana obrien Oct 09, 2006
    oh my gosh...thak you sooo much. I have talked to Maytag, Amana everyone I can think of and they cannot come up with anything regarding their OWN products. When I saw you posted the button portion of my microwave I knew you had the correct one.
    Thanks so much....Oh, what kind of lightbuld can I use? I cannot find a part number as I couldn't even find the model?
  • Kenmore Master
  • 9,098 Answers
That's made by Sharp and many of theirs (and other brands) require you to take the outer cover off to change the bulb. Here's how: Unplug the oven first. That's rule one! Remove all of the screws from the side and back of the outer wrapper / cover of the microwave. There are usually four on the rear edges and two on the bottom of the edges on each side of the cover. The cover then should be slid slightly backward then up from the rear and it will slide off. You may have to pat down on the sides to loosen it first. I use firm and simultaneous open-palmed slaps on both sides near the front, then pull it up and off. It is possible that some voltage will remain on the high voltage capacitor and can be conducted via contact with wires, connectors and components connected to it. If you stay away from all the wiring in the right rear (as you're looking at the front door) it should not be a problem. Unless there is a problem, the voltage should actually not be present. If you and the work area are clean and dry, and you only touch the light bulb while the cover is off, there should be no problem. Change the bulb. It may be held in with a bit of clear tape, too, so take a look at the socket first. When putting it back on, be careful that the inside front edges of the cover catch properly in the slots in the chassis. Good luck and be safe! Make sure it is unplugged!
Posted on Oct 09, 2006
  • William Miller
    William Miller Oct 09, 2006
    I must also mention to be careful while the cover is off and with the cover itself - the edges are sharp.
  • William Miller
    William Miller Nov 11, 2006
    Sorry I didn't get notified that you had posted a follow-up. I'll be sure to look in the future.
    I think you'd just have to take your old bulb out and look at it.
    It should be a standard cylindrical appliance bulb about 15-40W, but if in doubt, take it with you by all means.
    You should be able to find them in grocery stores and stores like Wal-Mart.
Change interior light In my ge pvm1870sm3ss microwave
have to take the outer shell off to access the light .
Mar 09, 2016 | GE Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
How to find and change the internal light bulb "philco microwave"?
I would Google the model number with replace bulb---You Tube has video instructions for a lot of models and if yours is there it will show you how.
Dec 17, 2012 | Microwave Ovens
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Change oven light on PanosonicNN/SD446W
If your owner's manual doesn't refer to changing a bulb, then you will have to disassemble the oven to do so.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
Oct 24, 2012 | Panasonic NN-SN657SMicrowave Oven
While changing the light bulb on the bottom of Whirlpool MH1140XM, the bulb popped. I replaced it but now all I get is a hum whether I push timer, light or oven settings. The oven appears to be heating...
Hello, Thank You for using FixYa. I will be helping you today.Make sure no wires were pinched in the process. The turntable motor runs off the board that's why im thinking you have a grounded wire somewhere.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Whirlpool MH1140XM Microwave Oven
The light is out.
Usually, you have to remove the outer case after pulling the power cord and wait for maybe 10 minutes to make sure the HV power supply has discharged itself. The lamp should be plainly visible at this point. Be sure to use the same wattage lamp as the original. Good luck!
Jul 02, 2010 | GE JVM1540SMSS Microwave Oven
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
Kenmore 63672 Convection/Microwave Oven Logo
387 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
