Question about Philips HDD1630 MP3 Player
Computer not reconzinig go gear
Computer not detecting go gear
  • TaraTheTiger Nov 07, 2008
    My computer isn't recognizing my player either.
  • Anonymous Nov 27, 2008
    Philips HDD1630 MP3 Player the first time I con
  • 8,596 Answers
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Why is my 1992 Cadillac devill 4.9 sluggish from take off
It might be in 3rd gear could be in limp in mode if computer detected a problem, hook up a scanner and have it checked for codes
Oct 28, 2015 | 1992 Cadillac DeVille
My GO gear Mp3 player wont be detected on any computer. even if you install the hardware, it wont still detect.
if your player don't detect . also don't detect with Philips Device Manager
try to download this driver for it usb 2.0 ADFU Driver .
i worked with 7 and in system device manager show "uknown usb device" but in XP show this "usb 2.0 ADFU Drive" and also the Xp itself install it . if your windows dosent have this so go on to download it manualy . then use philips device manager to repair it . i do it myself and it worked
Dec 13, 2010 | Philips GOGEAR SA6045 MP3 Player
ENGINE MALFUNCTION LIGHT STAYS ON
If the light was flashing when it came on, then it means your engine is misfiring.
A solid light can mean anything.
This light comes on when the computer detects a fault of some sort in its diagnostic tests. If it keeps detecting this issue, the light will remain on. If the light turns off, then it has detected that the issue may no longer be present.
In order to find out what the exact reason was for your light, You need to have your car computer scanned to retrieve the code that the computer would have stored when the light triggered. Most garages will do this free of charge. The code will tell you what may have caused the light to initially go on
Oct 02, 2009 | 2006 Jeep Grand Cherokee
My laptop computer says the adpter is not detected we have ran th
You can connect the Cat 5 cable from your laptop to one of the ethernet ports from router to download. Or download from any computer to a  Jump drive then install to your lap top.
Sep 08, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Iv tried to reset it while hooked to the computer but same thing
if its detected as a removable drive,format it...
if its not,try connecting to pc while holding the "volume -" button...
if its still not detected in philips device manager,i'm sorry!
Aug 31, 2009 | Philips SA5125/37 MP3 Player
Wont go into overdrive> and wont take off in the right gear
You have to scan it. The transmission is shifted by the computer and if it detects a problem, it defaults to 2nd gear and will not shift.
Can't do anything more without codes.
Aug 08, 2009 | 2000 Pontiac Firebird
Reverse gear engine cut out
look for a vacuum leak vacuum leak
Jun 22, 2009 | 2001 Suzuki Grand Vitara
Slipping into first gear when driving past 40 mph
Dodge has a safety feature on there trannys. Its called limp home mode. If the computer detects a problem with the transmission, it will eather put it in 1st or 2nd and not change just to let you get out of the road or home if your near. But when you restart the car i will reset till it detects the problem again. But for as what the problem is it will be hard to say. With computer trannys you can have it hooked up and scanned for error code.
Feb 15, 2009 | 2000 Dodge Stratus
Not Detecting Go Gear IN Xp
Connect your Go Gear to the computer
Open the Philips Device Manager - it came on the installation CD
Click on the Repair tab and follow the instructions
When in doubt, follow directions.
-Tha (Mean Grinch) Mp3 Doctor
Dec 21, 2008 | Philips GoGear SA178 MP3 Player
Philips HDD1630 MP3 Player Logo
62 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
