Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Code F1 How does one check the J-2 harness on the board and reseat it?
    President:
  • 878 Answers
You are going to have to kill the power to the range and open the control panel by removing the four 1/4 inch hex screws. These are located undernieth the control as you open the door. Then by holding the panel on each side pull out. The J-2 harness will be on the main board. The harness will run from the display board to the main board. You want to unplug the harness and plug it back in for a good connection. Of course you want to make sure the harness is not damaged or burnt. Since you had this in the clean cycle when the code came up, the temperature sensor should be checked. I'm getting conflicting information on this error code. One sections states it's the j-2 harness on the board and another section states an overtemp condition and to check the temp. sensor. If you have the expertise you can ohm out the sensor to eliminate it. At room temp it will ohm out at approx. 1060 ohms. To tell you the truth from past experience I would go with the temperature sensor first. This is the probe in the oven. Removes from the front and of course least expensive. I have two part numbers for this sensor..(typical Maytag) 12001357 and 704657. If your serial number begins with 10 it would be the first one. Catriver, post back.
Posted on Oct 09, 2006
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
I get F2:E0 F2:E1 and F2:E3 as well as the continuous beeping. Unplugging does not resolve the problem. I can turn on the oven, sometimes, but it goes off by itself. Sometime the controls don't work at...
Kitchen Aid Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line openfrom what this says you could have a bad touch pad,it says to press cancel,if the code comes back after a minute you have a bad touch pad.there's a tech sheet on you machine with all the codes on it,look behind the top console taped to the back.make sure you put this back,if someone comes in to work on your machine and that paper is gone it will be hard to work on it,all machines are different.
Apr 21, 2011 | KitchenAid KGST307 Gas Kitchen Range
Jen Air Convection oven keeps giving a F3 error code and F1 error code
F1
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common
problem. Refer to F1 test at the top of this page for more
information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor
(RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 07, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
F1 and F7 code ...how to fix it
f1 code is a communication error with the main board.the main EOC needs to be replaced.you can unplug the unit for a few minutes and reseat all the wiring connector on the back of the board make sure they are all seated properly.check you main power terminal block and ensure there are no problems with it.
Feb 23, 2010 | GE Kitchen Ranges
What does F1 fault code mean?
Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
Jan 08, 2010 | Kitchen Ranges
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Het3 Washer - F06 Code
dragon, drop the bottom panel by removing the 3 screws on the bottom, pull down and off. On the right side attached to the bottom of the door switch (on the inside) is a teardrop release tab. Pull down on it and the door will open. The F06 code is a motor tachometer error. The control is unable to detect the motor speed. While you have the panel off, check the harness that goes from the motor to the motor control board. The motor control board is the one on the bottom. Reseat the harness's for a good connection. If you can use a meter, check the motor windings, pins 1 to 2, 2 to 3 and 1 to 3 should read approx 6 ohms. Next, take the top off the washer by removing the 3 screws in back and sliding the top off toward the back. The main control board is in back. Make sure all the harness's are seated good. The third harnes from the right is the motor control power, reseat it. On the left side of the board, last harness toward the back is the serial communication link. Reseat it. On the motor control board on the bottom the communication link is the one toward the bottom, the center one is the motor connector and the top one is the power supply. If this doesn't solve the problem and your motor ohms out. I would tend to believe that the motor control board is the problem. Catriver..post back.
May 26, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F1 and F83 codes
Marsha, F1 is the code for a primary control failure. Since you just replaced main board check to see that all the harnesses are seated correctly. On this model I've found that if you have a pinched or blocked pressure tube,(hose going to the control board) it will give the same error code as a failed control board. Make sure it's not being pinched when replacing the consol. The F83 is the code for door unlock failure. You need to get past the main control board failure first...Catriver..post back.
Apr 20, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Code F1
jry, F1 code for the posted model number means the element relay energized when it shouldn't of. Some one has to check the J-2 harness on the board. Reseat it. If that checks ok, you will have to replace the power relay board. Catriver...post back.
Oct 08, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
109 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
