Question about Dell Dimension 2400 PC Desktop
Problem with Dell Dimension2400PC
When I log onto my computer I get 2 beeps and then a screen comes up. THe top few line says what thee bios is aand the type of computer it is. Then underneath that is says Secoondary drive 1 cannot be found Under that it says click F1 to continue or F2 to run the setup utility. I only have one hard drive so I dont know what it means bye the secondary driver. When I clicked F1 it continued as if nothing is wrong and wwas able then to log on. How do I fix this so that first screen doesnt come up.
  • edk164 Nov 05, 2008
    I tried your suggestion. On the driver section the secondary driver is listed as my cdrom i think and it already is listed automatic. So I dont think thats the problem. But thanks anyway
  • 112 Answers
Hit F2 to run setup.
At the HDD set up portion leave Primary drive as it is.
Set the Secondry drive to none or automatic.
Posted on Nov 05, 2008
My Dell laptop makes 12 beeps and won't start, why?
Unfortunately, they are bad news and omens of *****!
  • Beep Codes - General Hardware - Laptop - Dell Community > ... > Laptop > General Hardware There is a comment in the User's Guide that you should make a note of beep codes when contacting Technical Support but there is no list of the beep codes - this ...
  • Dell Optiplex and Vostro Beep Codes and Error Messages ... 1. OptiPlex Beep Codes. The computer might emit a series of beeps during start-up if the display cannot show errors or problems. This series of beeps, called a beep ...
  • Beep Codes and PSA Diagnostic Chart - Desktop Wiki - Dell > Support Forums > Desktop > Desktop Wiki Identifying Dell Computer Models Using the Model Code. On Sept 26, 2005 the System Setup program on certain Dell Dimension™, Inspiron™, and XPS™ computers was ...
  • Alienware Computer Does Not Turn On or Go Into Windows ... Dell support article tagged with ... The following tables illustrate the Beep Codes for Alienware Mobiles and ... For a laptop computer see if you can access the ...
  • Dell Inspiron 15R (N5110) Beep Codes Diagnostic Indicators > ... > Inspiron 15R (N5110) How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming ...
  • Dell Motherboard Beep Codes - What They Mean > ... > Computer Hardware Support 2010-05-23 · Technicians and computer users alike can use beep codes to troubleshoot hardware problems on all kinds of machines. This article lists Dell beep codes ...
  • Dell BIOS Post Codes - BIOS Central Dell BIOS Beep Codes; Dell BIOS System Messages; Dell BIOS Post Codes . Dell BIOS Beep Codes:
  • Step-By-Step: Deciphering BIOS beep codes - TechRepublic Discover what the beeps your computer makes at start up mean. ... Step-By-Step: Deciphering BIOS beep codes. ... Dell BIOS Beep codes for Dell computers ...
    Jul 31, 2016 | Dell Computers & Internet
    4 beeps on start up but no screen
    four beeps is ram I believe. Take everything off and see if it starts and then put stuff back one at a time and see what is causing the problem
    Oct 01, 2013 | Dell XPS 200 PC Desktop
    My optiplex 320 is making two high pitched beeps on starting boot, also im not getting anything on the monitor
    It sounds like the refresh rate is set to high. Since you do not mention what OS is installed I have listed information on how to change in Windows,XP.
    Start the computer and press the F8 key. Choose Safe Mode. Once the system gets into Windows follow the steps below and then restart the computer. If this does not resolve your issue email me at my email address below and include your OS information.
    How to Change the Screen Refresh Rate of Your Monitor
    1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
      Alternatively, right-click the desktop, and then click Properties.
    2. Click the Settings tab, and then click Advanced.
    3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
    • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
    • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
    • Changes to the refresh rate affect all users that log on to the computer.
    Or your system is giving off a beep code in which case the beeps come in a 3 beep sequence. Below is the beep codes and what each represents.Beep Codes
    Troubleshooting steps and more information about the OptiPlex 320 beep codes Beep Codes Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3-1 through 2-4-4 DIMMs not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller Test failure 3-3-1 NVRAM power loss 3-3-2 NVRAM configuration 3-3-4 Video Memory Test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No time tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math coprocessor test failure 4-4-4 Cache test failure
    Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
    Sep 18, 2013 | Dell Computers & Internet
    Cmos beep codes
    do you know which bios your computer is running ?
    AMI BIOS beep codes 1 beep - DRAM refresh failure
    2 beeps - Parity Circuit Failure
    3 beeps - Base 64K RAM failure
    4 beeps - System Timer Failure
    5 beeps - Processor Failure
    6 beeps - Keyboard Controller / Gate A20 Failure
    7 beeps - Virtual Mode Exception Error
    8 beeps - Display Memory Read/Write Failure
    9 beeps - ROM BIOS Checksum Failure
    10 beeps - CMOS Shutdown Register Read/Write Error
    Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
    1-1-4 BIOS ROM checksum error.
    1-2-1 System timer failure. (Programmable Interval Timer PIT)
    1-2-2 DMA (direct Memory Access) failure.
    1-2-3 DMA page register failure.
    1-3-1 RAM refresh failure.
    1-3-3 64K RAM chip or data line failure.
    1-3-4 64K RAM odd/even logic failure.
    1-4-1 64K RAM address line failure.
    1-4-2 64K RAM parity error.
    2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
    3-1-1 Master DMA register test.
    3-1-2 Mslave DMA register failure.
    3-1-3 Master interrupt mask register failure.
    3-1-4 Slave interrupt mask register failure.
    3-2-4 Keyboard controller failure.
    3-3-4 Screen (video) memory failure.
    3-4-1 Screen initialization failure.
    3-4-2 Screen retrace failure.
    4-2-1 Timer tick interrupt test failure.
    4-2-2 Shutdown test failure.
    4-2-4 Unexpected interrupt in protected mode.
    4-3-1 RAM test failure above address 0FFFFh (64K +)
    4-3-3 Interval timer channel 2 test failure.
    4-3-4 Time of day clock failure.
    4-4-1 Serial port test failure.
    4-4-2 Parallel port test failure.
    4-4-3 Math Co-processor failure.
    BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
    hope this helps
    Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
    Why is my lap top just intermittently beeping with a black screen
    Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
    Oct 07, 2012 | Dell Inspiron M5030 Laptop
    Just upgraded Vista to Windows 7. Now when computer boots, it repeatedly beeps (so many times I can't count them), then asks which OS I want to start with. Only Windows 7 is listed. It starts fine.
    Hello, if your computer peeps on startup it could be that your keyboard is stuck somehow thats why it beeps, it is sending and interupt request. try checking your keyboard to be sure its not stuck. happy new year
    Dec 27, 2010 | Dell Inspiron 1501 Notebook
    Beeping when i turn on and black screen
    IT is either one of three things.
    1. keyboard missing; check it's plugged in.
    2. graphics card; check that it has not been dislodged and is seated properly.
    3. memory. Are the memory cards properly seated?
    Apr 02, 2009 | Dell OptiPlex 170L PC Desktop
    My computer crashed and when i turn it on, there are 2 beeps
    Here are the beep codes for Dell. Count the beeps sequences and compare them to the list.
    Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
    Jan 29, 2009 | ViewSonic VA1703wb Monitor
    Dell PowerEdge 1600SC Server occasionally beeps when running
    Check out this site:
    Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
    Sep 26, 2008 | Dell PowerEdge 1600SC Server
    Dell Dimension 2400 PC Desktop Logo
    75 people viewed this question
    Alun Cox
