Question about HP Officejet 5610 All-In-One InkJet Printer
Scanner not working..
My scanner wont work. Keeps saying that I'm not connected even though I am. Everything else works, (i.e fax, print, copy) is there anything that I can do to get this problem fixed?
  • 1,605 Answers
This is what HP has to say about unable to scan
if this doesn't fix the problem, you have to uninstall adn reinstall the software.
Note: install the printer software on the computer first, then connect the printer to the computer.
Posted on Nov 05, 2008
Not able to print, keep saying 1 document on pending. I have deleted everything and still no able to print. scanner, copier and fax is working normally.
Your document is stuck in the printer queue. Usually you can fix this by shutting down the printer completely and disconnecting the power connection then starting over. Depending upon your computer and the software you are using it may be possible to have the computer empty the queue
Aug 22, 2013 | Brother MFC-7860DW Duplex Wireless Laser...
Mfc-j825dw keeps saying scanner cover is open and its not. how do i fix this
short of returning it for another look to see if the lever where the cover closes is not got tape or something preventing it from seeing the door is shut.
Aug 27, 2012 | Brother MFC-J825DW Wireless All-in-One...
Says scanner failure, scan, copy and fax will not work, did the print alignment still not working Only the printer works
try use a high quality usb cable, some usb cables has low bandwith, and give some strange, errors like scanner error, copy,...
Feb 09, 2010 | HP Officejet J5780 All-In-One InkJet...
All works fine except the scanner on the lexmark x5470...It used to work fine but the menu has reduced to image capture only but even that wont work
All you need to do is put in your page you want to scan, upside down and the wrong way round and hit scan. Then there wil be two buttons underneath the buttons which say print, scan, fax and it says start above it then two buttons which say black and colour if you want your copy in colour press colour or black!!
Dec 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Brother 9700 Quality of Rec. Faxes Is Good, Copies Light & Uneven
You need to go to reports and print out something like the user settings list. If it looks bad as well, then your toner or drum is at fault. if only faxes and copies look bad then you need a new scan assembly.
Jul 13, 2009 | Brother MFC 9700 All-In-One Laser Printer
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Scanner locked?
On some models there is a transport latch to lock the scanner. Look under the scanner (where the copy comes out) and you will see a green slide. Look down thgrough the scanner glass and you will see a lock/unlock symbol.
May 05, 2009 | Brother IntelliFAX 4100 Laser Fax
Scanner Failure, 'Power off and on' message - therefore, fax will not work
Scanner failure will not let you to make copies nad scan but you will be able to print from computer and receive fax.
Even then try the steps mentioned bellow:
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector (If possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing Printing from computer,
If you are able to print from computer you should be able to receive faxes.
Try printing a test fax.
Press Menu/Setup> Then press the right arrow key to locate Tools> Then Press Ok> Again press the right arrow key to locate Run Fax Test> And press OK
Check to see if it prints a Fax test
Good Luck
Aug 29, 2008 | HP OfficeJet 7110 All-In-One Thermal...
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
