Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi 50" VS 50605
Tv has constant horizontal lines going through it, started out as just a little annoying about 4 months ago and is now almost impossible to watch. would appreciate some help , i called around and cheapest was about $275 to get it checked out.
  • 1 more comment
  • Fruitcake Nov 08, 2007
    Mitsubishi VS-50705 Rear Projection Television
    Has same color horizontal lines on full screen.
    Is it worth repairing or should I sell for $150 (possible price repairperson offerered.)
    Thank you!
  • TEW1 Dec 30, 2007
    TV vs-50705 just cut off. When powered back on there was a blue line stretching from the left side of the screen to 4 inches from the right side of screen.
  • Adubs Jan 25, 2008
    TV has horizontal "jumpy" lines through it when I turn it on. After left on for awhile, as if to warm up, the lines stop. It started about 6 months ago, and would take about 1 to 2 minutes to "warm up" and get rid of the lines. Now, it takes about 30 minutes, and the lines are much worse when you first turn on. Cannot even see picture. Any suggestions?
    Sergeant:
  • 337 Answers
We need to know if the lines are of different colors or are they white and the screen is too bright ?, 275.00 seems a lot just to get it check out but it all depends were you are,in NY that could be a going charge but in pittsburgh it seems too much,please let us know what the lines look like.
Posted on Oct 09, 2006
  • Omar Urrutia
    Omar Urrutia Oct 09, 2006
    Please post it as a new question.
My tv has horizontal lines till it warms up,only a couple minutes then it is pretty much clear.it is a 42 inch projection tv.Is it the bulb?
This is a sign that you should be looking for a new TV. Tubes are getting old along with components and it takes more High Voltage when first powering it up that cause these retrace lines.
Feb 02, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Shaky picture once warms uphorizontal lines stream through it continuisly
there are some capacitors on the signal board that are associated with the pwer supply regulators off the 5 volt and other sources there that need to be replaced
if you have the tools and know how and soldering station you can do the repair your self if not then you might want to contact a servicer in your area
i can get you the cap location numbers if you like
Oct 24, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv problem
bias on green is too high or current is too high^^^turn bias down on focus block^^^--curved lines(not retrace lines) convergance IC`s going or resistor(s) out of range^^^replace them^^^
Sep 10, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Constant horizontal lines
Good Day, valscot;
The most common problem with model i some caps on the signal board, CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
good Luck big IRISH.
Aug 14, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS 5041 rear projection
if it has been four years since the set has worked you are going to ned all three CRT's I'm afraid, the tubes will go soft just from sitting and not being used. also I bet there are a ton of bad capacitors in this Tv set now also.
Jun 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
VERTCAL HOLD
Good Day, marvy21; try theses ideas, they will fix the TV # 3 is most common, you might start there. 1). VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.2). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. 3). CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Good Luck, big IRISH.
Jun 10, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Horizontal lines and screen bounce
These sets have capacitors that will go bad, but without a good ERS meater that tests these in curcuit you could be spending a lot of time doing nothing, But the most common is to find the 9 volt reg on the signal board and change all within a 2 inches of that regulator
Feb 07, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605
Code 23 means horizontal deflection failure. Check your horizontal output transistor. Or the horizontal drive transformer solder joints as well as the horizontal yoke pin connections for bad sloder.Hope this helps. if I can be of further assistance let me know
Jan 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
