Question about kawasaki Full Suspension Mountain Bike Men
A reg kawasaki gt 550
Was takeing my bike out the other day when it started to lose power and sounded like it was missing on at least two pots put new plugs in ,ran for a few mins ok then started to do the same again any ideas what might be the cause
I would say you need to have your coil checked.
Posted on Nov 12, 2008
Were do the two overflow hoses from the carb on my 1994 Kawasaki 550 GT connect to
Hi Gordon, I am sorry you can't find the first and best tool you ever bought for your Kawasaki but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://diagramas.diagramasde.com/otros/Kawasaki%20KZ500,550,GPZ(ZX)550%2079-85%20Service%20Manual%20ENG%20By%20Mosue.pdf
Sep 12, 2015 | kawasaki Motorcycles
Kawasaki vulcan 1600 not charging after riding in rain
get a volt meter and check the three yellow wires coming out of stator / generator. All should read over 12.6volts, all should have same voltage. if not, chevk plug connections for burning or, if they are good, pull out stator for testing.
If stator is good, replace voltage regulator unit, usually under seat near battery.
Jul 27, 2017 | kawasaki VN 1500 Vulcan Classic...
Have 89 gt 550 battery going flat when bike left lying for a few days.Tried to start her nothing put on lights to see and they go dead,charge the battery for about 5-10 mins starts fine.New battery in...
HI, CHECK CONDITION OF REGULATOR RECTIFIER, POSS WIRES ON THE PLASTIC PLUG HAVE CORODED, INSPECT THE WIRES FROM THE OUTER AND INSIDE THE BLOCK CONECTOR IF FITTED
Jan 10, 2011 | kawasaki GT 750 Motorcycles
I need a wiring diagram for a kawasaki kz 550. I cant get the battery to hold a charge and my ignition wont work i have to push the bike to get it started
Hi, Alicia sorry you can't find the first and best tool you ever bought for your Kawasaki despair not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
KZrider Archives Wiring Diagram KZ550 Kawasaki KZ motorcycles of the 70...
Kawasaki Motorcycle Wiring Diagrams
Aug 12, 2010 | 1981 kawasaki Z 550 F
Missing once high in the revs
when you cleaned the carb, did you remove the jets? Sounds to me like the high speed jet is plugged
Apr 28, 2009 | 1982 kawasaki Z 550 F
Hi, I have a H plate GT 550 the bike will tick
hello m8,,u have blocked main jets and idle jets, to do this u need to remove the carbs ,,turn them upside down, and remove the casing one at a time,take out the float,becarful not to damage the shut off needle thats attached to it,, unscrew the brass lookin screw which is the jet that the needle sits in,, and will have a number stamped on it, ie jet size, take a 8mm spanner and undo the stem that the jet has come out from and poke a needle or pin in all the little holes, hold it up to the light and u should see daylight threw the holes,, clean out any brown ,rusty lookin deposits from the float bowl casings to,,,,then put back together, repeat the same to the other 3 carbs,, and put back on bike,,this will solve it,,any probs come back and ill tell yuh,, cheers
Mar 26, 2009 | 1992 kawasaki GT 750
Kawasaki GT 550 - erratic tickover
Put a carby kit through it and clean, inspect and blow all ports through, check intake rubbers for any leaks, (pin holes can change air fuel ratio) Especially check for obstructions in your idle/bypass jet, do the kit first so you know its right, then tune your idle mix until steady.
Feb 24, 2009 | 1992 kawasaki GT 750
kawasaki Full Suspension Mountain Bike Men Logo
102 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
