Question about Ricoh FAX5000L Plain Paper Laser
SERVICE CODE 5-54
I HAVE THIS SERVICE CODE AND I HAVE NO IDEA ON WHERE TO LOOK FIRST OR PARTS TO ORDER.
    Genius:
  • 2,120 Answers
You have a bad fuser unit.
Posted on Nov 13, 2008
Service Call SC819
I found that this 'SC 819' occurs if you use the bypass tray for the scanner. I found also that this error can be fixed with an firmware update. See link. http://www.copytechnet.com/forums/showthread.php/32934-Ricoh-Aficio-2035-SC819-Error-Code?p=132762&viewfull=1#post132762
I have no idea how to do that at the moment, and I can't report the success of this way.
Jan 22, 2014 | Ricoh Aficio SP C240SF
Error code is call service 3 on the Panasonic fax kx-fl422
You need to contact Panasonic Service personnel to resolve any error code that begins with "call service." Please call or e-mail using the following contact information:
Obtain Product Information and Operating Assistance; locate your nearest Retailer/Dealer or Service Center; purchase Parts and Accessories; or make Customer Service and Literature requests at:
http://www.panasonic.com/help
E-mail Panasonic tech support via:
http://www.panasonic.com/contactinfo
For in Limited Warranty programming and Troubleshooting Support:
Office Advantage assistance and Service Location finder: 1-800-211-PANA (7262)
If the Limited Warranty has expired, contact Continued Services Technical Support Line at 1-800-435-7329, for fee based technical support. A credit card will be used to charge this fee.
Mar 07, 2011 | Panasonic Office Equipment & Supplies
I have a xerox 5312/5214 Copier and it is showing a message of U4. In the manual it says to call for service. The machine is an older machine and I don't know how much it would cost to fix. Is there...
The U4 code means you have a fser heat problem. The fuser is the assembly that heats up and "fuses" the toner onto the paper. It is located near where the paper exits the machine. There is a reset procedure you can use to try and see if the code will reset. If it does not then you would need to have it serviced. It is quite old and there is a concern wether it would be worth repairing. I would use www.partsdrop.com to get parts or more information if you need to persue a repair. I have used them quite a bit in the past.
Good Luck and Thank You for using Fixya.
Wheatland Services
Diagnostics:
To enter diagnostics: Turn on the copier while holding the '0' button...all control panel lamps will light.
To enter a code: Enter the first part of the code followed by the 'Start' button, then the second part of the code followed by the 'Start' button again.
Note: If an invalid code is entered, 'Er' is displayed. Press 'Stop' and enter a new code. *To clear a fuser code: Enter diagnostics, enter '52' followed by 'Start'. If a fuser code is current, the number '1' will flash, enter '0' to clear the code followed by 'Start' to lock in your selection. Press 'Stop' and then you can shut down.
Feb 13, 2011 | Xerox Office Equipment & Supplies
I have a Pinnacle 27 EZ load Laminator that keeps showing an ERROR CODE 02, nothing in my service manual showes me what this problem is, the unit will not run, HELP!
have no idea what the code means but i would hazard a guess and say the heater circuit isnt working ,take it apart and try a volt meter across the heater element
Dec 16, 2010 | Office Equipment & Supplies
Konica F-36-2 code on 7030. Removed the jam, but need to have the call service screen go away. Any ideas?
Sir/Mam,
First power off the machine. Then hold down the 2 and 5 button and turn on the machine. Hold down to you the 25 mode screen. Then touch Soft switch setting. The next screen you get your going to use the arrow buttons to put a 3 in the first box (LEFT) a 1 in the second box (middle) and change the 1 to a 0 in the third box. then touch exit power off the machine. If the code 36-2 comes back there is a problem with the Fusing Unit the hot part (sensor could have gone bad.). do not keep trying to reset. The machine is telling you its broke keep doing it could cause a lot more damage or start a fire. Get a technician out to look at it.
Oct 08, 2010 | Minolta Office Equipment & Supplies
Where can I get a Canon 720i fax manual.
Service manual? No...user manual or parts manual, yes.
Jul 30, 2009 | Canon LaserClass 720i Plain Paper Fax
Brother 2820 power supply
YOU MIGHT TRY GOING ON THE WEBB AND TYPE IN PARTS FOR BROTHER MACHINES. ONLY BROTHER SERVICE CENTERS THAT ARE AUTHORIZED CAN ORDER FROM BROTHER. GOOD LUCK BROTHER SR TECH
Dec 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Richo 3310 fax
To enter in to service mode press: "clear modes" ,107, "red cl " and hold the red btn for 30 sec
all in that order.
Aug 22, 2008 | Ricoh FAX5510NF Plain Paper Laser
What is an Info Code 21?
I just had the same problem yesterday. Code 21 is not listed but in checking with a supplier it is a fuser that needs to be replaced. $175 for the part and $90 for service call.
Feb 13, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Ricoh FAX5000L Plain Paper Laser Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
