Monitor communication This morning after I updated the RAM in my dx2200 I turned it on. It came on fine but the monitor was not receiving a signal. I tested the computer with a different monitor and it did not receive signal either. I tested both monitors with a different computer and they work fine. As far as I can tell without a monitor the computer is work OK. Is this an issue with the motherboard or something that can be repaired? These items were working fine yesterday and have been for at least 8 months.
    Sergeant:
    Novelist:
  • 196 Answers
Either the RAM is not fitted properly in the socket or the RAM is faulty.in any of the case it wont give you the display on the monitor.try refitting the RAM properly or replace RAM.
hope this helps you............
thanks.
Posted on Nov 05, 2008
    Genius:
  • 1,605 Answers
Monitor usually work fine without too uch porblem. but when it goes, it goes.
in your case. I suspect the video card may have pop out of the socket.
I don't see any other things can go wrong. I assume you change the RAM only and didn't touch anything else in the box.
turn off the machine. and reseat all or the device card.
    Scholar:
  • 155 Answers
Check out all the cables connected on the mother board.and all the cards connected firmly.remove all the cables and cards and refit then again and also check out the cmos battery.
thanks.
  • 13,433 Answers
Hi, Remove all ram from the computer, try starting it up, it will beep. Turn the computer off. Add the original ram. and try to start up again. You should get picture.
After this you can try adding the extra ram. If it doesn't work repeat what I told you and then possibly replace the ram you have bought if the problem doesn't go away after a few tries.
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Worked fine last night, discovered it this morning still turned on but no signal to monitor. Rebooted and it began a consistent beeping with no signal to monitor. Unplugged several times to no avail....
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
Dec 13, 2010 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
No Signal, No Beep, No POST
Try Replacing CMOS Battery...If you get no power to the motherboard its your power supply. Try reseating everything, processor, ram, video card.
Hope this helps
Mar 19, 2010 | ASUS A8N-SLI Deluxe Motherboard
There is no display in tbe monitor as well as cpu, what may be issue??
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card.
  • When the PC turn on there is any beep.
  • If no beep then your RAM is alright.
  • Problem in VGA Card.
Mar 17, 2010 | HP Compaq dx2200 PC Desktop
ASUS P4P2E-X 1 long beep that continue without end
hi,
I think One long beep that continue means RAM problem , Ram Can May be dead or faulty, check on other ram.
I hope that this has been very helpful for you
Nov 14, 2009 | ASUS P4PE2-X Motherboard
Ati radeon grafix card 9550/x1050 monitor signal out of range
Try to check the screen resolution and the screen refresh rate. Try to set it first to 60hz for the screen refresh rate and try to set the screen resolution to 1024 x 768.
Aug 31, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Computer stopped communicating with the monitor & keyboard
I agree, if you did a combo of keystrokes (re: cntrl+F5 for monitor) thats only a shortcut keystroke and should be able to do and undo all changes in "control panel">"display">"settings">advanced
Apr 20, 2009 | Acer Aspire M1641-U1521A PC Desktop
My monitor does not light up but just clicks
if ur monitor is not coming up... check uplugging the monitor cable from the tower.... if u receive a msg on screen "No input signal" or "No VGA Signal" then Monitor is working fine... if not received monitor is not working properly.
if Monitor working... open the tower and remove memory (RAM) and switch on the pc... u should get beep codes.. if u dint get it.... Motherboard gone bad....else... try inserting RAM in other slot... even then its not lighting up...RAM problem or RAM solt problem..
Aug 20, 2008 | Computers & Internet
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
