Question about Canon PowerShot A100 Digital Camera
Error message E25
When i turn the camera on is makes a soft whirring noise before displaying 'E25'. Replay is not affected but i have not tried to download my pictures to the computer yet
  • Anonymous Dec 31, 2007
    I have a Powershot a 200 and same thing is happening...
  • 641 Answers
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Posted on Aug 10, 2007
SOURCE:
New SD video camera Model SDR-S50. After taking footage, I am able to replay it. If I turn the camera off, once I turn it on and try to view the footage a NO DATA message is displayed.
I Have the exact same problem.....thought it was user error and never returned. Now it has been over 3 months and same thing still happens. Should the store accept it back?
Feb 13, 2011 | Panasonic SDRS50 Camcorder S
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
I have a panasonic lumix camera model DMC-FZ28. I flew to India two days back and when i arrvied I turned it on to take a photo. the display was very blurry and the camera was emitting a loud whirring...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 31, 2010 | Cameras
Camera freezes after startup
If you added an external memory card, try removing that first. I put an 8 gig mem in mine and it would just error out because it didn't support that much. Otherwise I would send it in.
May 17, 2009 | Polaroid i737 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Error message on display
Had the same problem, turn on camera wait until power up is complete and turn it off again. Give lens area a firm hit and turn camera on error should be fixed. try several times as it may not work first time. This worked for me hope it helps
Oct 16, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
E25 error on canon ixusi
Remove and reinsert the batteries to see if the error code will reset. Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost, you should decide whether it worth it.
Jun 09, 2007 | Canon PowerShot A100 Digital Camera
Canon PowerShot A100 Digital Camera Logo
170 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
