SOURCE: Universal remote control code
Sorry but my list only gives codes but not specific models but here goes anyway.0028,0044,0119,0126,0127,0128,0129,0130,0182,0199,0228,0260, the vcr codes are as follows.0298,0299,0340,0342,0343,0344,0367,0750 good luck
SOURCE: lost remote control. have universal RCA and
i found that your brand is not listed RCA code list,
your G&E remote is good one and easy to detect code for your tv.
solution
using your GE remote :
1. Turn on the device(TV) you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device(TV) button for the device you are programming . The INDICATOR LIGHT will
blink once then remain lit.
using your RCA controller:
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR
LIGHT will blink once then remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have retrieved all three numbers in code
i hope this will solve your problem
regards,
cseian
