Question about Minolta Maxxum STsi QD 35mm SLR Camera
Can't switch to autofocus.
I have a Maxxum Stsi. It was working fine yesterday, but now it's stuck on manual focus. "M FOCUS" appears in the window and pressing the AF/M button will not change it. Any suggestions before I send it out for service??
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
The autofocus motor is probably worn-out -- a common problem. Most shops can rebuild the brushes in the motor, since parts are no longer available from Minolta.
Posted on Nov 24, 2006
Polaroid 690 SLR-The switch between manual focus and auto focus, does not appear to operate normally. Maybe I do not know how to use it, however I cannot manual focus. Are you familiar with this camera and...
Not sure if this will help, but according to the manual, to use manual focus, push the button down until the red portion is visible, and turn the manual focus control dial until the image appears in focus in the viewfinder. Then, take the photo as normal. To return to autofocus, just return the switch to its normal position.
Sep 15, 2011 | Polaroid 690 SLR Instant Camera
Aoutofocus stopped working
Please remove the battery and and then insert it again and test to automatically reset the setting.
melnavz
Oct 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
Is it possible to manually control the focus on this camera? (Konica Minolta Maxxum 400si SLR 35mm Film Camera) I need to be able to manually control the focus, apeture, and shutter speed for a film...
The description of the manual focus is available in part 2 of the manual, page 40. The manual is available as a PDF here: http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html#si_series . It is the seventh camera in the SI series in the list.
To manually focus the lens, press the focus-mode button on the front of the camera (bottom left when you are behind the camera) until M. focus appears in the data panel. If you have an AF lens, turn the focusing ring until the subject appears sharp. If you have an xi-Series or AF Power Zoom lens, pull and turn the lens control ring.
The focus indicator will light when the subject is in focus. To return to autofocus mode, press the focus-mode button again. The camera will also return to the autofocus mode if you press the program reset button.
I hope this helps.
(in manual focus, you can take a picture even if the subject in the focus frame is not in focus. Often it means you need to take multiple pictures to get a good shot of the subject. The advantage is that you can get some interesting shots.)
Feb 07, 2011 | Minolta Maxxum 400si 35mm SLR Camera
Tamron 75-300mm lense quit focusing??
Check you have not switched camera t manual focus...if it's on auto then try changing various focal lengths to see if it kicks in....if it does intermittently you may have a cracked flex cable...this eventually happens with long throw lens because the cable gets weaken as it stretches and closes.It is also possible the ribbon became dislodged at the Circuit board just behind the mount.
Nov 20, 2017 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Can't get the camera to auto focus in dim light
you can maybe set the camera to manual focus, or override the autofocus so that you can take the picture.
Jun 13, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Sep 28, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Lost AutoFocus
Set focus - it is autofocus is it not? Take a few pictures and check whether they are sharp or not Also make sure your finger is away from the sensor window when holding the camera
Aug 07, 2007 | Samsung Digimax S630 Digital Camera
Minolta Maxxum STsi QD 35mm SLR Camera Logo
142 people viewed this question
Top Minolta Photography Experts
Parshiv Luthra
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
