Question about Belkin (F5D5231-4) Router
Wireless G Router
I have recently moved into a new house and brought my router with me (I have had no problems with it in the past). However in my new house the router does not work properly. It works fine when only once device is connected, but when I attempt to connect more than once device (i.e a second lap top or xbox) the connection drops and the router appears to crash and needs restarting. I have been onto my ISP (Ask4) and they insist its a problem with the router and I need to change the settings. However I'm not sure what I need to do so any help would be much appreciated.
Thanks!
    Scholar:
  • 53 Answers
The ask4 ISP has the following on their website.
"ask4 broadband works differently from most other broadband providers. With our broadband you do not need a telephone line or a modem, all you need is an Ethernet Enabled computer."
Assuming that this is the case, you need to make sure that your computer and other devices are hidden behind a standard firewall router, that supports NAT. (NAT stands for network address translation)
My other assumption is that by resetting your firewall router to the factory default settings. by and large this will enable a couple of things;
1 it will enable your router to obtain a Dynamic WAN address (this is the port plugged into the wall socket).
2 it will enable your routers inbuilt DHCP server, this will let your computers etc obtain a dynamic IP address + hide them behind your inbuilt firewall.
if you use the wireless option you will need to set this up from scratch, but I guess that you would have done this before. If you need further information check the routers user manual, just go to the manufactures website and search for your model the manual should freely avaliable.
Posted on Nov 05, 2008
Ipod touch losing wifi connection
If you are moving from place to place in the house, there may be dead spots? Are the other devices static? Is it the only device that moves about the house, all the time? Perhaps it's the Apple device, the antenna? Try at another location. Contact Apple, it may be a Known fault, You have heard of the antenna issues with the iPhone 5? If you hold it a certain way, it doesn't connect or will lose a signal.
Dec 26, 2012 | NetGear RangeMax Next Wireless ADSL2+...
Recently moved..stopped working after the move
your problem may be in the voltage that the dryer works on. If the cord is fine then I would check to see what voltage that may be supplied tot he dryer and if the dryer can operate on the voltage being supplied.
Dave
Jan 25, 2010 | Frigidaire Dryers
Have a 2Wire Router from SBC that has recently been causing connection problems with my sons XBox. Low signal roughly 2 bars. Nothin has changed in the house. Have router in main bedroom, Xbox is in son's...
if signal is fading in and out there are a lot of factors. 1 have you installed an other electrical epuiment in the house? emf cause interference. 2 if you move the xbox to the same room as the router how is the signal? d3 do you have a laptop to try next to the xbox where it is at now and see the signal? if it is weak on ther laptop also get a new router.4 if the signal is good on the laptop your xbox is the problem.
Dec 30, 2009 | 2wire HomePortal 100W Router...
Lost CD
Try using a separate card reader to download your pictures.
Sep 08, 2009 | Acer CE-5330 Digital Camera
Router issues in my apartment.
When to moved into the penthouse, there are more walls between the wireless router and the laptop in the bedroom. The walls are probably reinforced concrete walls which will stop or weaken the radio waves penetrating into different rooms. When you lived in a house this was not a problem.
The only way to solve this problem is to move the wireless router near an opening such as a door and move the laptop as close as possible to the wireless router to get a better signal strength.
The outer way is to install a wireless repeater or connect a long network cable to the router and the laptop.
Jul 29, 2009 | D-Link Dlink DES-3028P Switch 24-port...
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the...
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Sep 18, 2008 | Belkin Computers & Internet
Problems with router not issuing IP Addresses
u may setted mac filtering on teh router it wont allow new pc to communicate u need to to master reset connect teh power to the router look the back u can find reset hole take pen hit that and hold it for 40 sec and reboot the router by unplug teh power and wait 30 sec and replug it back and then u can login to teh router to change the settings>rate me solved if its helps thx
Nov 20, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
SMC signal suddenly extremely weak
login with ur router and change the channels>and use channel 11>1 and check with antena weather its straight looking the roof>and if its not works down grade or upgrade firm ware or use with out any security like wap or wep rate me solved if its help full thx
Oct 31, 2007 | SMC (SMC7004AWBR) Router
Belkin (F5D5231-4) Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
