Question about Acer AL1917W LCD Monitor
Acer AL1917 Monitor does not start up immediately.
Recently my monitor does not go on immediately after I bootup my computer. The off on switch flickers green intermittently and the screen remains blank. After 15 minutes or so the monitor lights up and works fine. Each day it is getting progressivley worse and taking longer. Today I thought it would never come on but it did after a half hour or so. It seems like you cant even turn off the off-on button. It doesn't respond.
When I put the computer into sleep mode the off-on switch turns amber. Start it up and its back to the same problem.
Any ideas?
  • krydor2002 Nov 06, 2008
    Thanks for taking the time to look at my problem. I don't have the confidence nor the know how to take a monitor apart. I appreciate your response
    Novelist:
  • 159 Answers
You'll need to have your power board -inverter redone.
The capacitors are starting to fail and that eventually will stop it all together.
I repair many monitors through ebay with these types of problems.
If you take it apart and send me a picture, I can usually see the problem areas.
ebays
bammbammfran
Posted on Nov 06, 2008
  • Fran Bednar
    Fran Bednar Nov 06, 2008
    The hardest part is taking the front trim off of the backing.
    Are you in the US or out of the country? I do repair these and sometimes shipping is cheaper than the local repair shops !!
External Acer AL1917 stopped to work with Lenovo 3000 n100 as an external monitor.
No signal means you have a different input enabled somewhere...like TV/HDMI/VGA ...you are set on some input other than the one you need for your cable. Check the menu settings, if you have a remote, try the input button and try a different setting
Jul 09, 2017 | Acer AL1917 19 inch LCD Monitor
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
Mar 08, 2011 | Acer AL1917 LCD Monitor
We have problems to open the case of the AL1917 which we would have to do because of a possible break-down in the power supply (no reaction to pressing the power switch). There are no screws visible, and...
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL1917&kategoria=monitor&kat2=schematics
It is typical these days how the monitors are put together. I use falt blade screw driver the separate the front and the back, starting at the bottom edge and work your way around.
See failed ACER monitors in my albums.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 29, 2010 | Acer AL1917 LCD Monitor
AL1917 LCD Monitor: IT SEEMS THAT THE MONITOR DRIVER HAS BEEN UNISTALL...
The monitor drive is only for allowing the resolution and some color adjustment that the OS may not have, the scrolling problem more like to be the PC mouse or setting problem.
May 18, 2010 | Acer AL1917 LCD Monitor
Monitor keeps flickering and seems like it's out of focus
Your monitor has a Power Supply Problem. It will fail no doubt soon. :( Take it to a reputable repair shop & get a "Quote".
Jan 19, 2010 | Acer AL1917 LCD Monitor
I need to know how to remove the footstand from my acer al1917 monitor pleas.
The wide black cover that seems to be part of the monitor on the back is in fact removable. Put your fingers/nails on the small gap on the underside and pull. There is some resistance but it is not too hard. Then you find 4 screws. Unscrew and voilà ... fixed!
Oct 20, 2009 | Acer AL1917 LCD Monitor
No display
I think the problem is on the resolution, or you can change the video card, but if its happen to another computer..then u have to contact the ACER support center
May 27, 2009 | Acer Computers & Internet
Acer AL1917A monitor freeze
acer al1917 go blank when change program
Apr 24, 2009 | Acer AL1917AS (Black, Silver) LCD Monitor
Monitor screen shaking and flickering
Check to make sure the cables are connected tightly. Wiggle the cable, does it get better or worse? Might need a new cable. And reseat the video card inside the computer. If that doesn't fix it, then yes you will probably need a new monitor.
Jan 15, 2009 | Acer AL1917W LCD Monitor
Acer AL1917W LCD Monitor Logo
659 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
