Question about Homelite 'Yard Broom' Leaf Blower
Husqvarna 145BT gas blower with a gas leak. this is at random some times it leaks from the bottom right down my lower back. Some times it doesn't leak at all. Not to sure where leak is coming from.
  • nohassle Nov 29, 2008
    I think there is a rubber seal inside the cap of the gas cap. mine can out but im not sure how to put it back in.
  • 7 Answers
I own the 145BT.
Mine will leak when one of the two tubes (one black and one yellow in the picture) that come out of the gas tank pull out. I find this is usually when someone hits them when priming the carburetor, just before starting it. I just push either the black or yellow tube back into the black rubber gasket on top of the fuel tank. The gasket is pretty tight so it sometimes takes a bit of effort.
More than once I had quite a bit of gas on my clothes by not making sure they were pushed in completely, before putting it on my back to start blowing.
The tubes should probably be a bit longer -or may have shrank a bit over time.
Posted on Aug 08, 2009
  • 48 Answers
You suggest it leaks 'right down you lower back'...I interpret this as when you are using suddenly feel gas..are wet, etc.
Perhaps it is not actually a leak, but a spill out of the gas-cap. This sounds like something that we all do now and again when we trim.
Maybe you are tilting it sideways to trim a sidewalk, tree, etc...and the gas 'leaks' through the hole in the gas cap.
Hope this 'fix-ya'...remember to rate...
Posted on Nov 06, 2008
Posted on Oct 22, 2011
Husqvarna chainsaw oil leaks
I have 4 husky\'s and they leak a little. On the bottom of the saw there is a oil flow adjuster screw turn it down a little also check oil cap gasquet.
Sep 21, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
My Husqvarna 41 will run fine for a while (up to 3 tank fulls of gas) then other times it will start and run but then bog down like under a load (but I just holding it and not cutting anything. Other...
Does this describe your problem.? 'Engine does not deliver full power or runs erratically'
Possible faults - Muffler carbonized, Piston rings leaking or broken, Secondary air seepage through leaking gaskets on carburetor spacer flange / poorly mounted or faulty manifold.
Aug 04, 2013 | Husqvarna Garden
I have a Rheem B33325 hot water tank, it is leaking from the pvc pipe that runs down the side of the tank. Help!
Sounds like TP valve is leaking:
Do not cap off TP valve.
Raise lever and gently lower back down to see if TP will turn off
Replace TP valve.
If problem persists, re-post question with specifics about your tank: such as electric, or gas, and if unit has a blower on top, and if gas control valve is electronic or has a dial.
Aug 10, 2011 | Rheem Water Heaters
What is the gas to oil ratio for the husqvarna 145 bt
Oct 25, 2010 | Homelite 'Yard Broom' Leaf Blower
1998 Grand Prix Interior Water Leak
yea on bottom rt of ur windshield is what is called the cowl black plastic piece arond the bottom of ur windshield underthat should be weather stripping that may have come off
Jun 09, 2008 | 1998 Pontiac Grand Prix
Homelite 'Yard Broom' Leaf Blower Logo
2,031 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
