Question about Sharp AL-1642CS Copier
Sharp 1642CS shared printer
I have a sharp 1642CS connected to a desktop running Vista Home Basic and it works fine. I have set it up for shared printer and when I use my laptop with Vista Home Premium when I print a test page it only prints blank pages.
  • dickf704 Nov 05, 2008
    The desktop has the new vista drivers installed and prints just fine. The laptop is set to use this printer as shared. It appears to get the drivers from the destop. There doesn't seem to be a way for me to load drivers for a shared printer.
  • Mike S
    Mike S May 11, 2010
    You have the wrong driver installed?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
You can go into your print driver and change the Driver. I dont think there is a difference between Home or Prem drivers. There is how ever a difference between 32 bit and 64 bit Vista?
When you set up the printer and share it from a PC, The printer attached to that PC can Control the Configurartion of the printer. PC's can either pull the driver from the sharing PC or you can select your own.
I would first check that the correct drivers are installed, (64bit or 32bit)
I would check the computer that is trying to print. replace the driver with the correct one.
You can open the print server -open the printers and fax folder, right click in a white area in that folder, a menu should pop up. Select Print Server from there you will see tabs, try to replace the driver from there.
Or Open the Printer Properties and there you will see Driver-Update in there.
This is a link to an explanation
Thou it was made for XP but the basic Infomation is the same.
-->Print a test page from The Printer Properties), if it works the Computer is fine, if you try to print from a program and it prints with errors. it is in the program..
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
Posted on Nov 05, 2008
On line button on copier
it must be shared for all to access. The online button can be pressed to stop the print process when adding paper or toner.
Feb 17, 2010 | Sharp AL-1642CS Copier
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can't print from my local printer with Remote Desktop
Try the following :
1. Go to Printers and Faxes
Right click on the printer u are using. Select Share this printer.
2. Set up a home or small office network with Internet connection connected, Printers on on both computers and identify both of them saperately.
For this you need to connect both computers with a cross cable.
3. after the home or small office setup is complete add a new printer from your Printer and Faxes menu. Search your printer automatically and choose it from the llist system provides and select the printer as default if needed.
4. Try taking a 'Test Printout' from the Concerned printer's properties page.
5. if this works, you have successfully installed the printer and are ready to take prints.
Mar 29, 2009 | Sharp AL-1642CS Copier
Sharp AL-1644 and vista 64
The quit making drivers for this product in 2005. Only Windows XP and below is supported.
http://www.sharpelectronics.info/Software.aspx
Sep 02, 2008 | Sharp AL-1642CS Copier
Belkin N1 Vision - unable to see networked printers
Go on the main PC and Press Start, Control Panel, Printers and Faxes, Right-Click On The Printer You Want To Share, Properties, Sharing...
... If it comes up ( If it doesn't skip to the next part )...
49a8fc3.jpg ... Click on "If you understand the security risks but..."
Click On...
Click Share this Printer, Apply, Ok. Now look on your laptop for network places and you will see the printer on the network.
If you need to contact me email jordylap1@fsmail.net
Jan 21, 2008 | Belkin (F5D5231-4) Router
Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Oct 10, 2007 | i-mate K-jam Smartphone
590 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
