Question about Sharp Office Equipment & Supplies
I keep getting an Finishing error F1-15. If I disable the the finisher it prints fine but without it disabled it won't copy at all...
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
You need to unplug it from the copier to use it, not just detach it.
1-if it has a stapler check to see if it is stuck, move it by hand w/power off.
2-check the bins of the finisher, is one side higher than the other? (NEEDS TO BE ALIGNED)
3-does it move up and down ? gear , motor, or sensor problem.
Posted on Nov 06, 2008
I'm trying to disable the safety on the top load fridgidaire washer because it keeps malfunctioning and not finishing the rinse cycle.
This is something that is designed into the feature of this combo stack unit and cannot be bypassed at this current time - from my research.
Dec 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have HP LaserJet 1160 Printer, moreover it prints dim (light) print on paper. I replace its toner, yet it is printing dim printing..... can you give me reason, what is problem?
Hi, maybe the printer is in EconoMode. To disable EconoMode please open the printig preferences in Windows. On the Paper/Quality tab or the Finishing tab, deselect the EconoMode checkbox.
Jul 19, 2010 | HP LaserJet 1160 Printer
HP LaserJet 4250 PCL 6 - Cannot get Duplex disabled
Try turning Duplex off at the printer. See if that does what you want.
Jun 23, 2010 | HP LaserJet 4250dtn Printer
Writing a word and it jumps and has me finishing
That's because when you're typing you are touching the touchpad. You should disable it while typing from the touchpad application or from your keyboard (you have a key combination you can use to disable it or enable it eg. Fn+F7)
May 25, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hp 3015 prints light with new oem cartridge
Machine may be in econo mode. To enable/disable.
Hope this helps
  1. open the Printer Properties (or Printing Preferences in Windows 2000 and Windows XP).
  2. On the Paper/Quality tab or the Finishing tab deselect EconoMode check box.
Apr 01, 2009 | HP LaserJet 3015 All-In-One Printer
Can not get the output tray to use the finishing tray.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
Let me know wat happen after.
Mar 24, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
I keep getting a box that pops up say that consent for UI has stopped working.. I'm unable to uninstall programs on my laptop. I have vista.. how do I fix it?
hi,
This is a known problem in windows vista (it is actually a security feature)
You can do either of following:
1. Disable UserControl from control panel.
2. If above doesn't works then change the registry settings [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System --> EnableLUA = 0]
3. if this even doesn't works, then, reboot your pc in safe mode (continue press F8 number of times after finishing booting screen on reboot, you'll get safe mode) and disable User control from control panel.
Hope this helps.
Thanks.
Mar 16, 2009 | Computers & Internet
Multiple copy error
Turn OFF sorting and/or grouping in the finishing tab.
Sep 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
44 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
