Question about Brother PC-6000 Pacesetter
I have a pc-8500 and the top thread breaks constantly. I have taken the side off...and see no thread tangled well as haven taken off the bobbin plate to make sure there is no thread tangled there either.
  • digger77 Nov 25, 2008
    I have the same problem. I just bought a PC 8500 used. I can't even sew a straight stitch without the top thread breaking. It and the bobbin are load correctly. I took off the plate and cleaned it thoroughly. I hand turned it with the plate off to see what was happening. it looks like the top thread is being pulled down into the bobbin area and becoming tangled on the shuttle. Is there any solution for this besides taking it to be serviced?
    Problem Solver:
  • 9 Answers
OK. I was just being kind of an idiot. I replaced the bobbin spool with one that came with it and it's working fine now. Apparently this machine is very picky about the type of bobbin you use.
Posted on Nov 26, 2008
Have a brother 8200 upgraded to a 8500. The touch screen seems to move to the right after some use. Is there a way that I can fix this or does it have to go to the shop.
Posted on Aug 23, 2009
Bobbin does not sew: the upper thread gets tangles underneath but the bobbin thread is not involved
bird nesting indicates that the needle thread tension is not tight enough
pull the thread out as if threading the needle and the tension is close when there is resistance to pulling the thread
Oct 11, 2017 | Brother Sewing Machines
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
Sewing machine
The top thread is probably breaking due to the bobbin thread tangling.
First-off fit a new needle .... do that anyway ! And if you haven't recently cleaned your machine (and you should do it every week as a minimum), clean-out under the stitch plate, remove the hook, clean the hook race and give it a small drop of oil, even if you're using the lightweight plastic hook/shuttle. Check that you have adequate bobbin tension ... when you pull the thread out of the bobbin case there should be a bit of resistance --- technically, this should be set-up using the correct tool and a set of weights, but if there is no, or very little resistance, you need to increase the bobbin tension a little bit at a time using the small screw that holds the tension spring down onto the bobbin case. This is a very fine adjustment, so you may find you only need to turn the screw less than a quarter turn to get it right. Ensure that, when you thread the top thread up, you do-so with the foot lifted so that the thread goes down properly between the top tension discs.If you're still not getting anywhere, check the basic timing/needle depth by looking at some of my other posts on the subject.
Nov 26, 2011 | Bernina Activa 140
The lower thread is getting tangled. I have changed the bobbin, re-wound the bobbin thread again, taken the bobbin out and cleaned the bobbin case.
Incorrect threading of the top thread can also cause lower loop tension problems. As can the wrong size or blunt needle. Try re-threading top thread first.
Dec 21, 2010 | Brother Sewing Machines
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
When I sew it only sews about 4 stitches the top thread breaks & sometimes the threads are all tangled in the bobin area. I found a small spring next to a larger spring loose. Where does the little...
You may want to take it to be looked at by a professional if there is a part loose.
I have constant problems with thread breaking and being tangled in the bobbin area with this machine. It can usually be remedied by adjusting your tension. Also, class 15 bobbins stink for this machine (yes, it says they're compatable, but they seem to be 1/8 of an inch too shallow and constaly become unthreaded from the bobbin casing). Try SA 156 metal ones.
Aug 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Thread breaks
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Jan 30, 2009 | Husqvarna Viking 1
    Sears Kenmore 1168280 (Old machine not used much)
    Untangle any mess under and around the needleplate very gingerly trimming threads as you go if necessary....remove and clear.
    Undo the needle clamp and remove the remains of the needle.
    Open the door for the bobbin and bobbin case and undo the clips holding the hook in place......don't force anything, just ease any tangle loose slowly.
    You may want to take a photo of how it goes back together if unfamiliar, or lay the bits out sensibly, so you can replace easily later.
    Inside the bobbin/hook area is the most likely region for thread jamming the motion of everything, so make sure all is clear and clean, then.......
    Without replacing the bobbin or hook, test the handwheel after cleaning before re-assembly.
    You may also want to check the take-up crank for thread jams........the small arm in the top cover that moves up/down to "take-up" the top thread has a cam attached to the top shaft and often tangles thread around the shaft, open the L side cover to access.......remove thread by unwinding handwheel manually ....again be patient and careful not to break threads.
    Best Wishes
    Jun 08, 2008 | Necchi 4575 Mechanical Sewing Machine
    Bobbin tangles up thread and jams machine
    Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
    Jan 30, 2008 | Brother XR-65t Mechanical Sewing Machine
    Sewing Machines Logo
    504 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
