Question about Maytag LAT2300 Top Load Washer
Maytag top load will not agitate or spin after belt replacement
Off balance arm was stuck. Removed control panel, checked all connections and and lid closed switch and it worked.
Posted on Nov 06, 2008
Agitator does not work
Your motor runs in forward and reverse...the spin is one way and the agitate is the other... that direction has failed. Replace the motor...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag atlantis will not agitate it runs through all the cycles it will spin but will not agitate. The belt is intact.
WELL THATS BECAUSE ITS AGITATED WITH THE XTRA LOAD YOU PUT IT THROUGH WHEN YOU ARE SITTING ON IT NOW I KNOW ITS FUN BUT SPIN CYCLE IS ONLY DESIGNED FOR WASHING CLOTHS...I HOPE THIS ADVISE FIXED YOUR PROBLEM.
Oct 31, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer agitates bit won't spin
If no one responds to your request try this site and others. This was a quick search on your model… I’m an owner and only have knowledge of the FAV6800AW…… Good luck .... Rich
Oct 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Matag Atlantis MAVT634 will not agitate
Does the motor start and run for agitation with the belt connected?
Jan 29, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
