Question about Sharp AR-M205 Copier
White stripes on pages copied from ARM 205
I recently changed the developer on my copier. After this I started getting black and white stripes on the copies. I cleaned the transfer charger and the black stripe disappeared but the white stripes persist. Any ideas?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
If you changed your developer? Or did you change the Toner Cartridge?
White stripe? Check the charge on the drum, it might have a piece of dust on it.
take the charge out, (dont take it apart) hold it up to some light, you might see some dust particles hanging in the grid. If so, rub very lightly with finger, do not use a cloth to clean. Blow it with a can of air.
Clean the transfer charge as well
Usually replace those as it is such a pain to clean on the smaller machines.
if you need any further help let me know
Posted on Nov 05, 2008
Fix a xerox 6350DT
If you have a white stripe in only one color, then you might have a bad developer. Each color has its own developer
116-2008-00 Yellow
116-2009-00 Magenta
116-2010-00 Cyan
116-2011-00 Black
Changing the developer is not super easy. You'd have to remove the left cover, HV Power Supply board, then remove Image Unit and the Developer Frame, where all the Developers are mounted. Detach the feed hose for the Developer you want to change and release the Developer's 2 spring clips.
The attached photo shows old developers which have dead spots that would cause the missing stripes on prints.
Sep 12, 2014 | Xerox Phaser Office Equipment & Supplies
Canon 7130 black and white copier. It looks like it is scanning but blank pages come out. I changed the toner and nothing. There are no alarms. also can this machine still be bought?
**** open the copier to see if the developer has fallen away from the drum unit or is the tab below where the toner is put in out of place. Sometimes, if out of place, when the copier closed shut the arm is moved to the right side of the post ( located on the lower half of the copier ) and move the developer away from the drum unit and produces light copiers or even blank copies.
May 17, 2011 | Canon NP 7130 Black and White Copier
We have a ricoh FW770 that keeps leaving toner on the print, we have to keep cleaning the drum in order to get a good copy
probably you need to change the drum cleaning blade. Its a long silicon rubber stripe that cleans the excessive toner from the drum surface.Also replace the developer units seals to prevent the developer and toner leak.
Hope that helps.
Mar 22, 2011 | Ricoh FW870 Black and White Copier
I have a white stripe on the copies. I just installed a new toner cartridge, and cleaned the transfer charger. I have a Sharp AR-162S copier that is 3 - 5 years old. Thanks.
Hi check the developer unit make sure it is coated end to end some times the blade on the developer gets foreig matter stuck and prevents the developer/toner to go onto areas of the developer mag roller also check and make sure the transfer corona wires are in good condition no black marks on the corona wire if there is replace the wires
Feb 15, 2011 | Office Equipment & Supplies
White strip on copy
While you make an printout, open cover when the paper is approx. in drum section.Remove drum, and you will see the picture on it, if the piece of picture missing, that is your white strip. On the drum you will see two blue small handles with markings pull. Dismantle it with help of this handle and you will be able to see the developer unit ( magnetic roller cover with toner ). If the white stripe also on it change developing unit, and drum unit.
Jun 22, 2010 | Canon ImageRUNNER 1670F Copier
My ir 400 gives a white spot
something could be blocking the primary chargeing corona wires/roller. i see it a lot on the ir 5000 when the primary corona assmbly cleaning pads get stuck half way through the cleaning cycle.
Jun 16, 2010 | Canon imageRUNNER 400S Copier
Streaking copies
Have you changed the drum unit recently or emptied out the waste toner in the drum unit? If not try to empty the waste toner and clean the area that is right under the drum unit... * Note* do not wear any thing white... Toner can make a vey big mess...
Jan 26, 2009 | Office Equipment & Supplies
Why does minolta copier print white stripes?
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Sharp arm 205
This worked only very temporarily and there is still the dust on the drum in the same location.
If this went away after you changed the drum and cleaned it out, I would guess it is something in the process unit itself. The Charge..
Is the Drum Scratched after a few copies? Is there a Band around the drum?
Are the separator pawls bad? Do they have movement, are they touching the drum? I have seen this collect dust, get stuck and ride on the drum scratching the drum...
There is the Cleaning blade, the other side is a piece of Mylar which also cleans, is it warped, bent.
If so I would replace the Drum Frame (they call it the Process Unit CFRM-0049QS51 , and the main charge, MC holder unit CHLDZ0035QS53 or what you refer to “wire cage in the drum unit”)
Open the top of copier; make a copy with the lid open. The page made should be black. This is called a Sky Shot, do this in between each thing listed below... look at each copy to see if there is a change.
do a sky shot,
open the side door as the paper just reaches the drum, your drum should have a consistent black around it. This is good a good way to find lines, is this happening before the drum or after.
If there are lines on the drum (no scratches on it) then it is in the optics, or process unit (drum/developer) or laser, if the lines are past this point,(no lines on drum) then it is in the charge.
This is what I would do if I were standing in front of your machine...
First. Open the side door on the right side, there is a transfer charge there. Clean that out with some air. And gently wipe it with a Lint Free Cloth.
Do a Sky Shot
Second: Remove the Drum, take the Charge Unit off the drum, clean it very well, hold it to light look for a spec of dust. You might think you have cleaned it, and not see it, when you make a copy does this line move if so, there is dust in the charge. do a sky shot copy..
To clean it, the Grid will come off with some needle Nose pliers, pull the one side with the tab to get it off, wash it off (soap and water works, drag you finger over it), let it dry, do no use any thing that will cause lint to get on it, the saw tooth part in the charge, you can use styro-foam poke some down in there. Put it back together, Make certain it is dry.
I usually replace this piece. All this is too much hassle, and it is a pain to get it back together.
Do a Sky Shot
The Charge is usually what cause's a white line…
As for the Developer and that Mylar bent piece. Look at it again, then in a week or two again. Bending it some times works for a little while. Is it turning brownish, and curling. If so it is old and needs replacement. This part comes in a regular maint kit, I believe it is replace at 150k copies (I could be wrong on that), I change it every other PM. I think this is the part number- PSEL-0001YSZ1 DV plate
It will collect developer and builds up and cause problems such as DV dumping, etc etc...
And changing your drum, did you use Setting Power. The drum and blade should have a little setting powder on it, if not this is necessary, otherwise your drum will squeak against that blade.
Nov 18, 2008 | Sharp AR-M205 Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-M205 Copier Logo
173 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
