Asegurate de que el freno de emergencia conecta a negativo (tierra), si el interruptor del freno de emergencia conecta a positivo entonces necesitas agregar un relevador para que conecte a negativo.
Firstly, lay all 3 speakers face down next to each other. Note the connections +- +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the center speaker(+). Take the center speaker (-) and connect to last speaker (+). The last terminal(-) will go to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
el mio tambien es un planet audio rxd2400 monoblock y me dicen que se proteje de echo donde lo lleve tenian otros dos iguales descompuestos de lo mismo osea ya son 3 no se si alguien sabe decifrar como reparar estos amplis mi correo para algun dato que sirva [email protected]
How do I connect my equalizer to my receiver? There are two methods of connecting an equalizer, by either using the tape monitor or the main pre-in & output jacks. To connect through the Tape loop, connect the EQ L&R outputs to the Tape-in (play) jacks of the receiver, then take the EQ L&R inputs to the Tape-Out (REC) of the receiver. On the front of the receiver you will need to select the Tape Monitor to access the equalizer.To connect through main pre-out/ pre-in jacks, connect the EQ L&R outputs to the receiver main-in inputs (pre-in), then connect the EQ L&R inputs to the main out (pre-out)
