Question about HP Pavilion F1703 17" LCD Monitor
HP Monitor Hello. I am sorry to bother you, however, you posted the comments : ---- I have repaired at least 50 of these monitors. It is a result of cold solder joints on toroidal coils. Since you have to take it apart to resolder the toroids replace the four push-pull transistors that drive the output transformers, they only cost about a dollar each. They fail on overheat and shut down the inverter. I have never had any of these monitors fail again after correcting these 2 issues. ---- I was wondering if you could tell me where I would purchase these transformers that are a dollar a piece. My screen is doing the same and I would rather replace than resolder. My email address is kathdiep@gmail.com Thank you in advance.
5 Suggested Answers
  • 349 Answers
SOURCE: Monitor repair
look in your local paper for monitor repairer,
but as the cost of a new monitors has come down so much ,i would consider a new purchase as the refresh rates and picture quality are far better now than when your monitor was produced,also second hand prices are very low .
good luck
Terry
Posted on Mar 10, 2008
SOURCE: Hp F2105 Monitor Repair Part for Dull/Flashing/Black Screen is Available Now
Thanks for this post my f2105 was doing the same thing now its working great. Thanks much!
Posted on Jul 03, 2008
  • 37 Answers
SOURCE: What are the toroidal coils?
On my monitor I had the 8 pin smt FET's short out. The CCFL transformers were not bad. You can use a ohm meter to determine if the transistors are shorted or open. If you use FET's like mine did, you can monitor the out put for voltage. Mine was 12 volts pulsed DC. Good luck.
Posted on Aug 26, 2008
Matampong
  • 153 Answers
SOURCE: Screen flickers, turns on and off
Normally this kind of problem needs only the dry soder, cause theres some loose components some where on the main board. Try to resolder any visiual suspicious terminals of components.Try to see carefully if any of the capacitor has any buldgy appearence on top of them. If there is try replacing them.cheers
Posted on Nov 23, 2008
How to increase resolution from 1024 x 576 pixels to 1280 x 600 pixels. I tried to change it by clicking start>control panel>display>settings but won't get desired results.
make sure wether the disply of your monitor and graphics card supports the resolution if the monitor doesnt support sthe resolution you will not be able to increase the resolution the mobilor becomes black
Sep 04, 2011 | HP Mini 1000 Netbook
Monitor stops displaying after a few minutes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
The picture board on your monitor is malfunctioning, since the power led or button is on and it randomly stop the dispaly signals, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 29, 2010 | HP w1907 LCD Monitor
Hello.
If your like me you probably have another computer around. We need to "Borrow" its monitor. If not see if a friend of yours has one you can use for a day.
Replace your monitor with the "Borrowed" one and fire it up. If you get the black out right away, try the previous tip with this monitor as well. If this Monitor works, then we have determined that YOUR Monitor has (In gaming terms) "Been fragged". If its an older Monitor its entirely possible that running L4D at max resolution might have been just enough to push it to failure.
If the "Borrowed" Monitor exhibits the same symptoms even after the test. Then the blame lies on your Video card.
Whichever one failed check to see if its under warranty (Not likely for the monitor unless it's less than a year old) But for the video card, if it's by a bigname manufacturer (ie... PNY,BFG, ASUS etc...) then try to scare up your documentation and receipt because alot of these companies offer a Lifetime warranty and you'll get your card replaced/repaired for free. Sometimes if its a discontinued model you even get a free "Upgrade"
If you don't have a warranty. Get a service quote. Find a place that'll give you a free estimate. If you can't find a quote for less than half the cost of purchasing a NEW replacement, then your better of getting a new one. because you'll benefit from "New" technology AND you'll get a warranty with it.
Sorry for the bad news
Hope this helps
Dave
Nov 24, 2008 | Video Game Consoles & Games
LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
Fan7601 vf48 Hp lcd monitor
hello stephentunga,
sorry mate, try hp service center near your place.
ty.
May 10, 2008 | HP vs19 (Silver) 19" LCD Monitor
Hpf1503 switches
Hello Patrick!
If you are technically able you can open the monitor and remove the key pcb( switch off remove power cable).Use a switch cleaning solution like wd40 to clean each switch (spray and operate a no. of times).This might solve your problem.Regarding where you can get it,Sorry I am in India and don't know where you might get it in your part of the world.
Please rate this solution and post your feedback.
Samir
May 03, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp mx 705 monitor the brightness menu appears andautomatically increases brightness to 100
Facing same issue in HP M704 from 12th Mar 08. It was working good for more than one year. Planning to contact customer support for service.
Mar 09, 2008 | HP mx705 17" CRT Monitor
Garmin 301
try syncing again or try replacing the battery of the HR belt
Mar 02, 2008 | Garmin Forerunner 301
Fujitsu c series labtop screen goes blank, the hooked up to a monitor, starts to work then says out of frequence and goes blank
The video resolution and/or frequency that's set in windows is not supported by the monitor you have plugged in. Restart the PC in VGA mode (hit F8 after the BIOS messages but before any Windows messages) and change the video settings to something basic, such as 800 x 600 @ 60 Hz. Then restart the machine normally.
Jan 21, 2008 | Fujitsu LifeBook C6555 Notebook
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
