Video or how to
This is a pretty big job, the whole primary needs to come off, clutches, compensating sprocket, and inner primary. you need to unbolt the swingarm, remove the left side isolator, unbolt left shock, carefull sneak the belt between the trans housing and swingarm. If you wanna tackle this yourself. your are gonna need a manual, there are alot of specs to follow. you really need to look closely at the 3 transmission seals, any wetness, i would change them, i usually change them all anyway. you need to change the inner primary seal and starter shaft seal while you're in there.
