Question about Muratec Copier
Unable to install Muratec driver on XP
Hi - I have a Muratec 1450. I am able to scan to the pc and copy. However, I cannot print from the pc to the copier. I have tried deleting the driver and re-installing. Doesn't help. I cannot get the driver to function after download. Is there anything in XP that would block this. Have had techs out twice, will work for a few hours, then nothing. Please advise.
  • Tim Babcock
    Tim Babcock May 11, 2010
    How is your copier connected to work as a printer?
    Is it networked or not?
If you are trying to use the pcl driver you need the optional pcl500 card installed
Posted on Jan 01, 2009
The copier/printer is connected to both computers through ethernet. While our "main" computer is our server, they are basically two linked computers not a big network kind of thing. The ethernet connects the printer to both computers but I can only print from one.
Posted on Nov 05, 2008
What happen when toshiba e-studio print blank and scan Black
Try deleting the printer driver and installing an updated driver from Toshiba's web site.
Jul 26, 2016 | Toshiba Office Equipment & Supplies
Printing keeps printing jibberish without a print job
Easiest cause of that problem is printing with wrong driver. If IP's have changed you may be printing with an HP driver or some other brand. If it's not that easy then you may have to clear out everything from memory, which means emptying out several files that are on the OfficeBridge compact card inside. That requires a card reader attached to a PC or laptop. We've never done this without being on the phone with Muratec, making sure we didn't delete the wrong directories from the OB structure. How did it start or happen? Was there a series of lockups? Partially-printed faxes?
Apr 18, 2016 | Muratec MFX2550 Black Toner Cartridge...
I have Muratec 2010mfx, It stop printing but still I could scan and use copier portion, its hooked up with our local area network and our network is up. Thanks for all your support in advance.
Contact the people that set it up for you...sounds like IP address may have changed ...the machine requires a static ip address...see if you can ping the machine.
Jun 11, 2011 | Muratec Copier
Dear Sirs/Madams, I have a Muratec MFX-1930 network multimachine (printer,scanner,copier,fax). Everything is working fine i can print, fax, copy and scan. My problem is the scanner scans to internal...
Unless your machine is connected via ethernet cable.( NOT USB.!!) you will not be able to scan directly to a Network folder. can scan to a Network folder if its an RJ45 cable but NOT if your using USB.
If you are using ethernet the machine should have come with the appropriate software...if you have lost it you can get it at .
**If you are using USB...installing the Network software will NOT make it scan to folder.
Apr 01, 2011 | Muratec Copier
When copying a document the copy comes out all black, what is the poblem??
do you have the users manual??? if not get one at this address then try printing out a list or report of some kind...see if its still all black. If pages printed from memory are ok does the lamp undert the glass come on when you make a copy.???
Sep 14, 2010 | Muratec - MFX-1300 Copier
Memory overflow
maybe if you have the owner's manual...try consulting that or...
Try this:
Jan 06, 2009 | Muratec Copier
MFX -2380 (Muratec) issue with net work printing
In network environments the muratec's usually have to have the setup disk run. They do not work on the standard TCP/IP port. The disk creates a muratec port for the pc to print to.
Jul 21, 2008 | Muratec MFX-2830 Black and White Copier
Cannot access scan function
Hi , did you try a manual copy thru the printer operator panel to make sure that there are no issues with the hardware , if it is copying manually then its an issue with the software , you need to uninstall the printer drivers through the Printer Disk ****make sure to disconnect the printer cable from the computer before uninstalling the drivers **** once the printer drivers are uninstalled restart the computer and get into the Safemode (**keep tabbing F8 when the system restarts for safemode**) and delete the following Folder " SPOOL " it is located under C:\WINDOWS\system32. after deleting the Spool folder restart the computer and install a fresh copy of drivers it will resolve your issue.
Do let me know once you perfrom these steps.
All the Best.
Jul 10, 2008 | Dell 922 All-In-One InkJet Printer
Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Jun 22, 2008 | Muratec MFX-1430 Copier
Muratec Copier Logo
323 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
