Question about RCA F35670MB 35" TV
Rca f35670mb tv works great but has really bad curved sides
  • 85 Answers
Hi there.im not familiar wih the model,but your fault lies in the east west correction circuit.excessive width usually means a short circuit e/w modulator diode,with the curved sides.normally,a narrow picture with curved sides points do dry jointed/open circuit polyester capacitor.if a firm slap has an effect,then its most likely a dry joint which makes for an easy life.the vast majority of east west correction circuits are based in tle line output stage,and generally not complex to fix.hope this helps,regads,steve.ps. look for s/c by 299 and by 228 diodes,check those..
Posted on Nov 05, 2008
I have a 1996 RCA 36" model # F35670mb and I am trying to get reception from a coax cable supplied by dish network, for a second room. I have connected the cable but I get no picture at all. Can you help?
You need to setup the dish receiver designating the channel for the second TV, typically a UHF channel like 21, then tune the TV to that channel.
Aug 12, 2010 | RCA Televison & Video
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
RCA model R61WH76 Chasis itc222 has 3 color curved band lines on
Your model doesnt have convergence ICs. You can get the replacement parts and free instructions on how to do the repair at the following link, just click on the contact us link on the lower left hand side of the website and tell them the model number and chassis they respond quickly.
http://servicemanuals.vstore.ca/
Apr 11, 2009 | RCA R61WH76 61" HDTV
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
Green convergance wont adjust, bowed screen
Green really shouldn't be adjusted, you adjust red and blue to the green. When a color is bowed that indicates that a part or two are bad, probably the convergence output IC's and possibly a fuse or fusible resister. You may need a tech to come adjust it for you because after replacing IC's the adjustments should be done in the servicers menus not just in the consumers menus.
Mar 13, 2009 | RCA P52937 52" Rear Projection Television
Teac M805SR TV Screen curving out at the sides
Hi
your Unit have defective. horizontal Streach.. a buldge Capacitor or Leak Capacitor This is the result. Replace the Capacitor to back to normal
Thanks
Likha!
Sep 25, 2008 | Televison & Video
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
TV won't power up and blows the fuse
A 10 year old RCa most likly has a bad Horizontal output transistor as well as the main High Voltage transformer and The transformer is no lonmger available from RCA. The replacement wont last longer then a year if your lucky. My advice on a set this old ?? Buy a newer one!!
Sep 11, 2006 | RCA F35670MB 35" TV
TV WONT TURN ON
Sounds like the typical high voltage xformer problem
Sep 07, 2006 | RCA F35670MB 35" TV
Televison & Video Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
