Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Hot water not going into washing machine
I have a frigidaire Gallery washing machine. when I switch the knob to do a hot wash, not hot water comes into machine. I've already took the knobs off to see if the hot water works and it does. the machine is just not allowing hot water to go in.
  • Anonymous Mar 12, 2014
    only hot water is coming into the machine
  • 734 Answers
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Posted on Dec 12, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Frigidaire front load washer does not fill.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Aug 04, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire gallery front load washer does not use cold water when cold cycle is selected.
Either the cold water valve selenoid is not working or the control panal is bad. try swapping the hot and cold hoses and then call for hot water, if it fill with cold then the cold water valve is probably bad.
Apr 28, 2011 | Washing Machines
My (gallery) front load is making my load dirty after the wash. I noticed that if I wash in cold water is not as bad as when I wash with warm/hot water.
Sounds like deposits or dirt coming from hot water tank or line running to washer.Turn off water supplies to washer and remove the hoses from the back to see if the filters/strainers in each port are dirty.If not add a little CLR to the washer and let it run a cycle.Hope this helps.Wouldnt hurt to check the drain strainer either on the bottom of the wassher if you remove the little access panel, might be something in there making water dirty
Jan 20, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a frigidaire gallery front load washing machine that I purchased about 4-6 years ago. The softner will not dispense. I have taken the entire dispense unit out and have run hot water over it to try...
Add white vinegar to the dispenser and run a load. If that does not solve the problem take the dispenser out and soak it in a 50:50 white vinegar and water mixture for an hour
Sep 24, 2017 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
Washing manchine water overflowing over the top
where the hoses go into the machines you will notice those valves are controled by solnoid switch thats what starts and stops water flow as you turn selector knob you should hear them click if that turn off water supply remove hoses from back of machine check if filter screen is in place and that there is no trash keeping valve open p.s switch from hot and cold to see which one needs to be replaced or repaired
Nov 19, 2009 | Frigidaire GLWS1339CS Top Load Washer
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire gallery
The choices are: cold hose kinked, water supply valve closed too far, cold water solenoid stuck or bad or clogged.
Mar 28, 2008 | Frigidaire GLWS1233A Top Load Washer
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
999 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
