Question about Campbell Hausfeld 20 - Gallon Air Compressor
Electric motor stalls
Why would the electric motor slow down and eventually stall out at 70 psi on a oil bath 120psi compressor?
    President:
  • Campbell Hau... Master
  • 1,388 Answers
A compressor can stall before completing a cycle if the motor is not receiving correct power, such as when there is an extension cord being used or outlet is overloaded with other appliances. Other problems that cause this condition are in-tank check valve is leaking pressure back to the pump and weak or failed capacitor. Some volt meters have setting for checking caps. Reject the capacitor if reading is 90% of rated value. Rare problems include worn bearing or bad contacts on pressure switch. enjoy
Posted on Nov 29, 2008
My sears air compressor model 919.156781 will not pump up past 40 psi , then motor then compressor stalls and motor gets hot , have to unplug . I have had the motor checked
When it gets to 40 psi turn it off and see if you hear air leaking down from somewhere....if so listen and feel around the edges of the compressor head. If you hear or feel air leaking there you may need to replace a head gasket.
Jun 13, 2014 | Craftsman 20 Gallon Portable Horizontal...
Motor stall
if the motor has 3 phase ( test the terminal motor for voltage) if there are the motor need repair, brushs, ball bearing, or winding faulty)
2) if the motor is 1 phase, the capacitor or centrifugal switch is faulty or windin run or starting can be faulty. However in ANY case try to TIGHT ANY wires loose or connector, or corroded contacts in the relais or contactor, clean with alcohol isopropyl or c.solvents.
God bless you
Nov 07, 2013 | Psi Ar Vip Electric Pressure Washer: 110...
My compressor bogs out to the point it will stall the motor and blow a fuse. it happens on the third cycle at about 110 to 125 psi
change the run capacitor on the motor,its getting weak,there may also be another capacitor for the start circuit,replace them both
Mar 05, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Hello; could you please help me to find the answer for this question; 1) what exactly is the surge, and what is the difference between surge and stall? please explain in a simple language because i have...
Stall is the state the armature is in just at startup. Your compressor will draw maximum power at stall. Some say there is a small surge some nano-seconds after the compressor gets rolling ... just as it begins to slow to operating speed.
A electric surge is a temporary increase in line voltage doe to any of a hundred reasons. There is a surge in your home everytime a motor starts. Lightening strike.
Have I properly addressed your question? or have I missed the boat.
Can I recommend Wikiedia for additional reading?
Thanks
Oct 19, 2009 | Air Tools & Compressors
Electric motor labors when restarting
to long of a cord or to small of Gage wise or filters are clogged or compactor on the motor is going bad.
Jun 28, 2009 | Coleman CP0302013 20 - Gallon Portable...
Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Jun 18, 2009 | Air Tools & Compressors
Suzuki samurai fuel issue
try and pull the carb and check your jets and make sure that they are cleen and air filter be perty cleen if that does not work and you thing it is a fuel problem then check your fuel line and fuel filter and see how cleen they are it may be as simple as dirt clogging your fuel or something worse but try that
Jan 14, 2009 | 1989 Suzuki Samurai
Campbell Hausfeld 20 - Gallon  Air Compressor Logo
481 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
