I had soup simmering and saw that the burner indicator light was off. Soup also had stopped simmering. I turned it back on and within a minute or two it turned itself off again. I did this several times and it turned itself off within seconds thereafter. I know it's not just the light/light bulb. The burner actually shuts off.
SOURCE: oven door is locked
i took the grids off the burners and gently pushed a screwdiver in the gap between the top of the stove and the area where the lock is. Then i slid the lock to left. Presto! open!
SOURCE: the off button does not shut off oven for kitchenaid kgsa906
I would suggest that you both check with Kitchenaid (Whirlpool) to see if they have done some kind of extended warranty since this sounds like it may be a design flaw.
SOURCE: BUner indicator light stays when
I would suspect a failed sensor instead of the LED. A replacement may solve the issue.
